Accelerated Motion Problem-easy but I NEED HELP on it
The discussion clarifies that horizontal motion in projectile motion maintains a constant velocity, while vertical motion is influenced by gravitational acceleration. It emphasizes that any change in direction, such as in rotating or oscillating motion, constitutes acceleration, even at constant speed. The conversation also notes that constant speed can occur in the absence of retarding forces like air resistance, particularly in a vacuum or on a frictionless surface. Additionally, the assumption of a uniform gravitational field is crucial for analyzing such motion. Understanding these principles is essential for solving accelerated motion problems effectively.
physicsbhelp
[SOLVED] Accelerated Motion Problem--easy but I NEED HELP on it!
Is NOT an example of accelerated motion?
e. Horizontal component of projectile motion
What happens to the horz component of the velocity in projectile motion?
Yes, since it stays constant.
Well - one could look at each answer and think about the acceleration involved.
Going vertical near a massive body, e.g. Earth or moon, a mass will experience the force (acceleration) due to gravity.
Something that involves a change of direction (something rotating, swinging, oscillating) is accelerating, even if it maintains constant speed.
The last answer would seem to infer constant speed (and velocity) provided a retarding or dissipating force (e.g. air resistance or friction) is not involved. Such would be the case in a vacuum or on a frictionless surface.
Also, we have to assume uniform gravitational field.
i.e. that it doesn't change direction/orientation so as to affect motion perpendicular to the field.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
