Acceleration as a function of position
15 replies · 3K views
DrLich
Why can't I simply integrate a(x)=m*x with respect to x to determine the speed of a particle as a function of position v(x)=1/2*m*x^2+A?
Acceleration is ##a=dv/dt##. It is a derivative with respect to time. What would it mean to integrate that wrt position?
I stumbled upon the following exercise:
The acceleration of a particle is given as a function of position:
a(x) = (2 s^-2)x
I needed to calculate the velocity at a given position x. I initially thought I could solve this by integrating the acceleration function with respect to x to find the velocity as a function of position, and then put in the x-value to get the answer. Sorry if this is a silly question.
Well, ##\int a(x)dx## has dimensions of ##\mathrm{L^2T^{-2}}##, so that clearly isn't a velocity.
I assume ##s## is a constant. Have you come across simple harmonic motion in your studies yet? If so, do you recognise the form of your equation? If not, I'd suggest a quick google of the phrase and see if that helps you any.
$$ a(x) = \frac{dv}{dt} $$
Use the Chain Rule on the RHS to change the independent variable from time ##t## to position ##x## before you separate variables for the integration.
I think ##s## is the dimension.
$$a(x) = 2 x [ \text{s}^{-2}] $$
a(x) = (2 s^-2)x
I suspect that ##s^{-2}## means Hertz squared.
If you have a position ##x_0##, then it is a position at a certain time ##t_0##, namely ##x_0=x(t_0).## What we have is ##a(x(t))=\overline{a}(t)=(2s^{-2})x(t)=\dfrac{dv(t)}{dt}## since ##x(t)## is a function of time and ##a(x)=a(x(t))=\overline{a}(t).##
This means
\begin{align*}
\int_{t_0}^t \overline{a}(t)\,dt &=\int_{t_0}^t \dfrac{dv(t)}{dt}\,dt= \int_{t_0}^t dv(t) =v(t)-v(t_0)=(2s^{-2})\int_{t_0}^{t} x(t)\,dt
\end{align*}
and
v_0=v(t_0)= v(t)-(2s^{-2})\int_{t_0}^{t} x(t)\,dt = \left.\dfrac{d}{dt}\right|_t x(t) -(2s^{-2})\int_{t_0}^{t} x(t)\,dt
I have no idea what the integral of position over time would stand for, but that is your velocity at time ##t_0## and position ##x_0.## But you need a second information ##t## for the integral and the velocity at that time.
You do not need to call ##t## time. You can as well call it a parameter that parameterizes the path of your positions.
$$\begin{align} & a=\frac{dv}{dt}=\frac{dv}{dx}\frac{dx}{dt}=v\frac{dv}{dx}=2~(\text{s}^{-2})x \nonumber \\
&\implies v~dv= 2~(\text{s}^{-2})x~dx. \nonumber \end{align}$$Need I continue?
The [path] integral of instantaneous force times incremental displacement is known as "work".
Just give the accelerating object a unit mass. Then you can bring a whole pre-built set of intuitions to bear on the problem.
Like noting that the net force acting on the mass is conservative: ##F_{\text{net}}=m~(2\text {s}^{-2})~x.##
a(x) = (2 s^-2)x
Note that acceleration is the second derivative of displacement. So, we have:
$$\frac{d^2x}{dt^2} = \alpha^2 x(t)$$That might look familiar!
It is also useful for finding ##x(t)## and hence ##v(t)##. However, here we need to find ##v(x)## and for that I think the work-energy theorem is the least circuitous method.
You can't, because it’s missing details. To find speed from acceleration, you need more information. Integration needs initial conditions to give a complete answer. Just knowing acceleration isn't enough.
DrLich said:
a(x)=m*x
has an exponential solution since [itex]a=\frac{d^2 x}{dt^2}[/itex] and you have a 2nd-order differential equation for [itex]x[/itex] when [itex]m[/itex] is a constant.
By the way, if you know [itex]v[/itex] as a function of [itex]x[/itex],
then you can write [itex]v[/itex] as [itex]\frac{dx}{dt}[/itex].
Your original equation has been re-expressed as a 1st-order ordinary differential equation for [itex]x[/itex].
This one could use the specification of the initial conditions. The solution of the second order homogeneous differential equation given in post 12 has a form that we should all know=two linearly independent exponential type solutions with two arbitrary multiplicative constants that get determined by the initial conditions, but it would be nice to hear from the OP.
