MHB Calculating Acceleration on the Surface of Venus
To calculate the acceleration due to gravity on Venus, the mass of Venus is determined to be 4.86×10^24 kg, which is 81.5% of Earth's mass, and its radius is 6.05×10^6 m, representing 94.9% of Earth's radius. The formula for gravity on Venus is derived as g' = GM_V/R_V^2, leading to the conclusion that g' can be expressed in relation to Earth's gravity. Using Earth's gravity value of 9.81 m/s², the final calculation yields an acceleration of approximately 8.87 m/s² on Venus. Additionally, a rock weighing 75.0 N on Earth would weigh about 62.5 N on Venus due to the difference in gravitational acceleration.
SantiagoHill
Friends, hello everyone!
Please help with this calculation.
The mass of Venus is 81.5% that of the earth, and its radius is 94.9% that of the earth.
(a) Compute the acceleration due to gravity on the surface of Venus from these data.
(b) If a rock weighs 75.0 N on earth, what would it weigh at the surface of Venuse?
Mathematics news on Phys.org
a) You probably already have a formula for g' (the acceleration due to gravity) but here is the derivation anyway:
[math]F = \dfrac{GMm}{R^2} = m g'[/math]
[math]g' = \dfrac{GM}{R^2}[/math]
So if the mass of Venus is [math]M = 0.815 M_E[/math] and [math]R = 0.949 R_E[/math] then what is g'?
b) On Earth w = mg. So find m. On Venus w' = mg'...
-Dan
a) The mass of Venus MV represent 81.5% of the of the Earth. So, the mass of Venus is
MV=(81.5%)ME
(1)
Where ME is the mass of the Earth. Plug the mass of Earth into equation (1), so we can get MV by
MV=(0.815)ME=(0.815)(5.97×1024kg)=4.86×1024kg
The radius of Venus represent 94.9% of the radius of the Earth. So, the radius of Venus is
RV=(94.9%)RE
(2)
Where RE is the radius of the Earth. Plug the radius of Earth into equation (2), so we can get RV by
RV=(0.949)(6.38×106m)=6.05×106m
The weight w of a body is the total gravitational force exerted on it by all other bodies in the univerce where this gravitational force F is given by Newton`s general law of gravity by
F=GMVmRV2
(3)
Where RV is the radius of Venus, m is the mass of the body. As we mentioned above, this gravitational force equals the weight of the body which is mg, so using equation (3) we get the acceleration on Venus by
mg=GMVmRV2
gv=GMVRV2
(4)
Now, we plug values for RV, MV and G into equation (4) to get gv
gv=GMVRV2
=(6.67×10−11N⋅m2÷kg2)(4.86×1024kg)(6.05×106m)2
MV=(81.5%)ME
(1)
RV=(94.9%)RE
(2)
F=GMVmRV2
(3)
mg=GMVmRV2
gv=GMVRV2
(4)
gv=GMVRV2
You are missing some division operators but otherwise correct.
Here's a bit of a shortcut.
Define [math]g' = \dfrac{GM_V}{R_V^2}[/math] and [math]g = \dfrac{GM_E}{R_E^2}[/math]. We know that [math]M_V = 0.815 M_E[/math] and [math]R_V = 0.949 R_E[/math]. Then
[math]g' = \dfrac{GM_V}{R_V^2} = \dfrac{G (0.815 M_E)}{(0.949 R_E)^2} = \dfrac{0.815}{0.949^2} \dfrac{G M_E}{R_E^2} = \dfrac{0.815}{0.949^2} \cdot g[/math]
and now you can use g = 9.81 m/s^2.
-Dan
In order to get a better and more complete explanation of the solution of this problem, I advise you to go to https://plainmath.net/38641/the-mas...-the-earth-and-its-radius-is-94-9%-that-of-th and read the information here. In addition, you can find other useful information here.
Thanks for the advice.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
16K
  • · Replies 22 ·
  • · Replies 40 ·
