Acceleration-free twin paradox
jethomas3182
Split from: https://www.physicsforums.com/threads/acceleration-and-the-twin-paradox.779110/
I find the discussion about acceleration confusing. I want to avoid that.
So try this scenario: Lucy is traveling at .6c relative to Bob. Just when they reach their point of closest approach, one kilometer, they synchronize clocks.
As their distance increases, each of them sees a red shift. Each estimates the other's time is dilated by a factor of gamma, that is 1/sqrt(1-.6^2)=1/sqrt(.64)=1/.8
After some distance, Lucy meets Betsy who is traveling the opposite direction at .6c relative to Bob. When they reach their point of closest approach, one kilometer, Lucy gives Betsy her clock's current time and Betsy sets her clock by it. Betsy and Bob will both see each other's light is blue-shifted. They both calculate the other's time is dilated by a factor of gamma = 1/.8.
When Betsy and Bob reach their point of closest approach, one kilometer, they exchange times. Which clock will be ahead, and by how much?
I believe that scenario is pretty simple..
I also believe that is crucial, so we will say 5 minutes has passed on Bob's clock since Lucy passed and synced her clock, we can call this sync 00:00. At this time 4 minutes has passed on Lucy's time dilated clock and she syncs Betsy's clock to 00:04. Since she would be the same distance from Bob it will take another 5 minutes on Bob's clock until she passes him. At that point her clock reads 00:08 and Bob's clock would read 00:10.
Let's say that 4 minutes has passed on Lucy's clock when she sync's Betsy's clock.
Lucy's situation is exactly equivalent to Bob's, and she has exactly as much reason to think that Bob's time is dilated compared to hers, as Bob has to think her time is dilated compared to his. Her clock reads 4 minutes so she can calculate Bob's proper time, it is 3.2 minutes.
Independent of Lucy, Betsy has every reason to think that Bob's travel at .6 c will cause his time to dilate. If her clock reads 4 minutes when she reaches Bob, it is predictable that Bob's clock will have advanced 3.2 minutes.
Since both of these independent inertial frames are as valid as Bob's, and they are clearly sequential, one starting at precisely the time and place that the other ended, Betsy is justified to conclude that Bob's proper time is 6.4 minutes.
But of course Bob's actual proper time is not 6.4 minutes or 8 minutes but 10 minutes.
Why is it that Lucy's view and Betsy's view are both wrong?
Because their velocity distorts their perception of spacetime.
Ah! I have an alternative view. Betsy need not take Lucy's view of things. From Betsy's point of view, Bob is traveling toward her at .6 c. Lucy is traveling toward her at .88 c.
So from her point of view, Lucy's time is dilated even more than Bob's. If I read it right, not just .8, but .47.
So Betsy will figure that Bob's clock goes 3.2 seconds when Betsy's clock goes 4 seconds, but she will also figure that while Lucy's clock went 4 seconds Bob's clock went .8/.47 seconds, about 6.8 seconds! So she should calculate his proper time at approximately 10 seconds! My answer was a bit off from that, but I rounded and maybe the right answer will be exactly 10 seconds.
This is what I imagined by your description. Lucy and Betsy would pass at 1.2c relative to each other...
Yes, but you can't just add velocities. When they're in the same or opposite directions, you add them like this:
V1 + V2 = (V1 + V2)/(1+V1V2) Where V1 and V2 are fractions of lightspeed. Like .6 c.
My calculator says that 299,792,458 m/s (c) times 0.6 = 179,875,474.8 m/s. Since Lucy and Betsy are presumably headed in almost the opposite direction their velocity relative to each other has to be nearly double so 179,875,474.8 m/s times 2 = 359,750,949.6 m/s which is undoubtedly > c.
Bob's clock will be ahead; as you say in a subsequent post, his clock will read 10 minutes, and Betsy's will read 8 minutes. Of course this result is simple to derive in Bob's frame.
If you try to analyze the scenario in Lucy's or Betsy's frame, the key thing you have to include, that it doesn't seem like you're including, is relativity of simultaneity. Bob, Lucy, and Betsy all have different simultaneity conventions, and that fact must be included when you are comparing readings on their clocks.
You also need to add velocities correctly using the relativistic formula, which jethomas3182 gave you. If V1 = V2 = 0.6, then their relativistic "sum" (i.e., the relative velocity of Lucy and Betsy) is (0.6 + 0.6) / (1 + 0.6 * 0.6) = 1.2 / 1.36, or about 0.88.
That is the first I've ever heard of it and I am quite curious where it was derived from...
The way I read it, Betsy's clock will have advanced 4 minutes since she left Lucy. She might not feel it appropriate to count Lucy's 4 minutes, but might instead translate them to the time that seems right for her own frame. But it's a picky point.
I don't see what to do about that. The events I look at are Bob and Lucy together at the same time and place, Lucy and Betsy together at the same time and place, and Betsy and Bob together at the same time and place. We never have to think about any other simultaneity.
Google for "relativistic velocity addition".
If A's speed relative to C is ##u## and B's speed relative to C is ##v##, then A's speed relative to B will be ##(u+v)/(1+uv)## (measuring time in seconds and distance in light-seconds so that ##c=1##). If it weren't for this, the speed of light would not come out to be ##c## for all observers - try setting either ##u## or ##v## to one to see what I mean.
According to the OP, Betsy sets her clock to read the same as Lucy's when she passes Lucy. That's why I said her clock would read 8 minutes when she passes Bob.
It's a basic fact about relativity; you can Google for it, as Nugatory suggested, or check any relativity textbook.
It is possible to reduce or abstract the situation in the twin paradox to 3 space-time events (2 clock synchronization events and 1 clock comparison event) giving rise to 2 space-time intervals [1] and still resolve the paradox without any reference to or use of acceleration. By resolve I mean both in a qualitative manner in that the apparent symmetry between the twins, which gives rise to the paradox in the first place, can be seen to be an asymmetric situation, and in a quantitative way giving the difference in clock reading at the last event.
Of course, without acceleration the traveling twin cannot turn back home, so one has to settle for three non-accelerated clocks instead. Alternatively the 3-event model can be said to give a lower limit for the situation where the traveling twin uses arbitrarily high acceleration to turn around.
[1] http://en.wikipedia.org/wiki/Spacetime#Spacetime_intervals
Which removes the core of the "paradox". If both twins stay inertial, and just exchange information via light signals or other travelers, the situation between them is symmetrical, and there is no "paradox".
[..] Lucy gives Betsy her clock's current time and Betsy sets her clock by it. [..] Which clock will be ahead, and by how much?
If you understood the correct answers in the "acceleration" thread (but I'm afraid that not all answers there were correct), you would know that the calculation is just the same as for the extreme case of nearly instantaneous turn-around.
In fact, you replaced one break of symmetry but another but equivalent break of symmetry. For the calculations it is irrelevant how you realize the change in velocity. But, there is of course no harm in elaborating that simple fact. :)
On the contrary. The paradox stems directly from the "symmetry" of time dilation where two identical and non-accelerating clocks moving relative to each other will measure the rate of the other clock as slower than their own. The twin paradox situation is a "naive" attempt to construct a thought experiment using that symmetry of time dilation so that it leads to (apparent) inconsistency. A more careful analysis of course shows that there are no inconsistency and that the situation is not symmetrical since the traveling twin is at rest in different reference frames at different times. You can either use acceleration to make that shift or, since the original poster expressed interest in an acceleration-free model, just use a single event.
By the way, note that the 3-event model, by definition, uses space-time events; there is no need for light signals. The traveling twin is still represented by a world line, although its not a smooth one as if finite acceleration is used. By replacing the traveling twin with two clocks which are at least as capable of measuring time as the twin is (drama aside its not really the actual biological age of the twins that are interesting, its how we measure and compare time in a relativistic framework) I think the resolution to the paradox is more clear. Since the symmetry breaking in the twin paradox comes from the shift of reference frame as the traveling twin undergo acceleration, and in the 3-event model that shift of reference frame is replaced with a single space-time event synchronizing a clock in one reference frame with a clock in a another reference frame (clock synchronization is the basic building block of any thought experiment in SR) you end up with a much simpler model. To me this one event resolves the paradox just as fine as acceleration would, but I understand if others perhaps are uncomfortable leaving out acceleration.
I don't think that one person keeping track of time on a single clock is symmetrical to two people exchanging timekeeping information between two clocks.
I understand your motivation, but I don't see how it is pedagogically supposed to resolve the student's issue.
To the extend that it is the time interval measured by the clocks that are interesting it should not matter whether we use one or two properly synchronized clocks if we want to know the total time interval. Disregarding acceleration also mean that you do not have to care if the rate of an accelerated clock is independent of acceleration or not, which is nice if you are new to special relativity (and people pondering the twin paradox usually are).
It was my intention to make him aware of the use of space-time intervals as way to very easily come up with the equations needed to answer his question. In fact, they are a very useful tool for any problem in special relativity that can be modeled with space-events, a tool that I think is often overlooked.
Still don't get how either of these two travelers can be believed to observe Bob's clock tick slower as Bob would realistically see their clocks as both slow. If they could see "Bob's reality" moment by moment his clock is ticking faster.
But there is no frame (and can't be) where all three of these events happen at the same place. So in order to analyze all three events in any frame, simultaneity will come into play. The only way to avoid it is to just look at the lengths of each of the sides of the triangle formed by these three events; and those side lengths are 10 (Bob/Lucy to Bob/Betsy), 4 (Bob/Lucy to Lucy/Betsy), and 4 (Lucy/Betsy to Bob/Betsy). This leads to a "traveling" result of 8 (4 + 4) and a "stay-at-home" result of 10, as has already been said.
For anyone who is not co-located with Bob, doing this requires a simultaneity convention. And Lucy and Betsy have two different simultaneity conventions. That's where the "gap" is. The Usenet Physics FAQ article on the twin paradox (which is well worth reading in its entirety) calls your objection the Time Gap Objection, and explains how it is resolved.
No, I don't think that's right. Both of them see Bob's clock ticking slower. Each of them sees Bob's clock ticking 3.2 seconds while their own ticks 4 seconds.
This is required by SR.
But we can't just add 4+4 to get 8, and we can't just add 3.2 + 3.2 to get 6.4.
Arithmetic doesn't work that way in SR, just as we can't add velocity .6 c to velocity .6 c to get velocity 1.2 c.
I don't think that works.
Try this -- somebody is traveling at a speed so large that one of his seconds is equal to 1000 of yours. He arrives at your location and you are interested in something that happened 4 second ago by his clock. Then you wait another 4 seconds by your clock.
What kind of calculation would you be doing where it's appropriate to add his four second to your four seconds?
4+4=8
There might be a situation where that's appropriate, but I don't understand it yet.
But those two intervals of 3.2 seconds do not cover the entire length of Bob's worldline between the two meeting events; i.e., they do not cover the the entire length of the third side of the triangle in spacetime (see below). There is a gap in between them, 3.6 seconds long, corresponding to the change in simultaneity conventions between the outgoing and ingoing legs of the traveling twin's trip (or between Lucy and Betsy, if you look at it that way).
Sure we can. Each 4 is the length of one side of a triangle in spacetime. Adding the two together gives the combined length of the two sides. This can then be compared with the length of the third side (10). It's just geometry.
A calculation comparing the sum of the lengths of two sides of a triangle in spacetime with the length of the third side, as above. Again, it's just geometry.
Physically, the sum of the lengths of the two sides gives a very good approximation to the proper time experienced by a traveling twin who turns around very sharply at the vertex of the triangle between the two sides of length 4. Understanding that this calculation is just geometry, and doesn't depend on your choice of coordinates, can help to drive home the point that the traveling twin will be younger than the stay-at-home twin when they meet up again, and that that fact is independent of your choice of coordinates; it's an invariant fact that arises from the geometry of spacetime.
I'm no saying you're wrong, but I don't understand it.
What I see is that when you convert from Lucy's time to Betsy's time it converts to 6.8 seconds. Betsy thinks Lucy's clock is slow relative to hers, even slower than Bob's clock is relative to Lucy's clock. There's no gap, just a conversion.
Usually when I add two vectors I don't just add their lengths. There are times when that's appropriate, like when you want to measure a perimeter. But I don't yet see that it's appropriate now.
Look at figure 4 of this page from the Usenet Physics FAQ article. The left (vertical) side of the triangle corresponds to Bob's worldline. The lower right side corresponds to Lucy's worldline. The upper right side corresponds to Betsy's worldline. The two sets of blue lines are the lines of simultaneity corresponding to Lucy and Betsy. Notice the gap in the middle of Bob's worldline, where no blue lines intersect it.
The numbers in question (the two 4's and the 10) are not vectors. They are lengths of sides of a triangle in spacetime.
Which is effectively what is being done here.
It's just replacing light signals with a slower communication method, a third traveler. But as long as you don't bring the twins together, there is no frame invariant age difference between them, so no paradox.
I don't really understand this. Let's suppose i send a probe from Earth to a light second away in one direction.
Another probe in the opposite direction a light second away.
Now i send two relativistic protons in opposite direction. Will they hit the two probes (two light seconds away from each other) in one second according to my clock or not?
If the first (two light seconds in one second), than what is their speed compared to each other from my viewpoint?
  • #31
No, because the protons can't move at the speed of light. It will take them longer than one second to travel one light second. If we suppose that the protons are each moving at, say, 0.9c relative to you, then it will take them each 1 / 0.9 = 1.11 seconds to reach their respective probes, according to your clock.
(0.9 + 0.9) / (1 + 0.9 * 0.9) = 1.8 / 1.81, or about 0.994c.
  • #32
Sorry, i knew not exactly one second, but something close to it. Of course almost light speed or light speed isn't the same.
However if their speed compared to each other is 0.994c, then how can they cover two light seconds distance in 1.11 second? Ok with a speed of sqrt(3)/2 you can get a length contradiction of 2, however, theoretically they could reach a speed closer to c, and get bigger length contradiction, but the time to reach still will be more than a second.
  • #33
In a reference frame in which either one is moving at 0.994c, they don't. You are comparing speeds in one frame with distances in a different frame, and that's going to give nonsensical results. Also, you're ignoring relativity of simultaneity, which is also going to lead to nonsensical results. You need to transform the coordinates of all the events of interest from one frame to the other, using the Lorentz transformation, and then analyze the scenario in the new frame.
In the frame in which the Earth is at rest, each proton covers 1 light second in 1.11 seconds, for a speed of 0.9c. The distance between the two protons, in this frame, does increase by 2 light seconds in 1.11 second, but that distance divided by that time does not correspond to the speed of anything, because speeds don't add linearly in relativity (they do in Newtonian physics, but experiments have shown that Newtonian physics does not correctly describe reality in this regime, relativity does), so it's not a problem that this calculation gives a result greater than c.
First, it's length "contraction", not length "contradiction".
You are still ignoring relativity of simultaneity. You can't correctly analyze this kind of scenario just by applying length contraction and time dilation factors. As I said above, you need to transform all the event coordinates into the new frame (a frame in which one of the protons is at rest), and then analyze the scenario in the new frame.
  • #34
There is a "convention" that defines simultaneity within any specific inertial frame (e.g. the Einstein convention). A convention is necessary to establish a time coordinate throughout the spatial dimensions of an inertial frame. The same convention is used in each inertial frame to establish simultaneity specifically for that frame. Thus simultaneity is not global, but relative to the frame of motion. Without this convention we cannot measure the time that elapses between two events in an inertial frame that occur at different positions in that frame. Without it we cannot even assign time coordinates as is routinely done in Minkowski diagrams.
In the paradox, two things happen absolutely simultaneously (because they happen at the same place) when the traveler instantaneously reverses direction. The traveler moves from an outgoing inertial frame, where his clock defines current time throughout the spatial extent of that frame, to an ingoing inertial frame. The traveler's clock does not change at the instant of turnaround. Thus the traveler must assign the value on his clock as the current time throughout the ingoing inertial frame. By definition of simultaneity in the two different inertial frames, the simultaneous time on the home clock abruptly changes in the traveler's frame of motion.
The article on the "Time Gap Objection" says "the apparent "gap" [on the home clock] is just an accounting error, caused by switching from one frame to another.
This is more or less true, but slightly misleading. To be clear it is not really an "error". It is quite true given the definition of simultaneity. Furthermore it can be shown to be a gap by physical experiment (however difficult that experiment may be).
An important thing about this "gap" is to realize that the home clock does not "jump" in reality. That is, an observer at rest near the home clock will not witness any such a jump. The jump only occurs from the perspective of the traveler's changing frame of motion. That is it happens in this changing frame. (This is somewhat analogous to the change in position of every object in your field of vision when you turn you head.)
Also, there is nothing mathematically inconsistent about analyzing the twin paradox in this way in order to determine what the value on the two clocks will be when the traveler returns. If there were, there would be an inconsistency in special relativity as described by Einstein.
This analysis has been attacked as incorrect with misunderstandings and tangential or discursive references in the previous thread. If someone feels that this analysis is invalid, that it contradicts SR, then it would be enlightening for everyone interested for that someone to demonstrate precisely why it is not a valid way to determine the time difference upon return of the traveler (in addition to application of the Lorentz transformation of time on the outgoing and incoming legs).
  • #35
The first "happening" is not really a happening, as you describe it; changing your state of motion does not "move" you from one inertial frame to another. It just changes how your worldline is described in all inertial frames. What physically happens at the turnaround is that the traveling twin experiences proper acceleration: he fires rockets or otherwise exerts a force on his ship to change its motion. If the traveling twin chooses to switch his description of physics from one inertial frame to another when he turns around, that's a choice he makes which is perfectly valid but not required by any physics.
The second "happening" is fine, but it only applies to the traveling twin's clock. It does not apply to other clocks that are spatially separated from him (such as the stay-at-home twin's clock). If the traveling twin chooses to change which inertial frame he uses to describe his motion when he turns around, then that change automatically changes the reading on the stay-at-home twin's clock that is simultaneous with a given reading on the traveling twin's clock. I don't think you disagree with this because you say the sme thing yourself, just in slightly different words.
Can you describe such an experiment?
"Reality" is a loaded word. A better way of stating this is: events which are close together on the home clock's worldline will have the home clock displaying time readings that are close together. But different inertial frames may pick different events on the home clock's worldline as happening "now" (i.e, simultaneously with some faraway event), and those different events don't have to be close together.
This is equivalent to saying that it happens because the traveler changes his simultaneity convention, which is what I was saying. Changing frames, in the sense you are using the term (at least, as you appear to be using it most of the time--see my next comment below), necessarily includes changing simultaneity conventions.
If "in this changing frame" refers to an inertial frame, then this is not quite right, because there are two different inertial frames, involved, not one. it happens because the traveler switches from one frame to another for purposes of describing what's going on. As I said above, there is nothing in the physics that requires him to do this; it's just a choice he is free to make (or not to make).
If "in this changing frame" refers to a non-inertial frame in which the traveler is always at rest, then we are back to all the issues with non-inertial frames that have already been discussed in this thread, and I don't see the point of rehashing them. All of this is a question of words anyway, not physics; we all appear to agree on the physics, as in the actual observations that the different observers make. The only discussion we are having is about how to describe those observations in words.
Of course not. As long as you correctly calculate the gap, and include it in your prediction of what the home clock will read when the traveler returns, you will get the right answer this way, yes.
  • #36
The OP's question has been answered, so this thread is closed.
