Acceleration of an electron in both a magnetic and an electric field
The discussion focuses on calculating the acceleration of an electron in the presence of both an electric field (E = 4 N/C) and a magnetic field (B = 4 T). The forces acting on the electron were determined using the Lorentz force equations: Fm = q(v × B) and Felectric field = qE, resulting in forces of -6.408 × 10-19 N for both fields. The total force was calculated to find the acceleration, yielding a value of a = 4.508 × 10-7 m/s2. Key insights include the importance of vector direction and the application of the right-hand rule for determining force direction in magnetic fields.
  • Understanding of Lorentz force equations
  • Familiarity with vector mathematics and cross products
  • Knowledge of electric and magnetic fields
  • Basic principles of particle motion and acceleration
  • Study the right-hand rule for determining force direction in magnetic fields
  • Learn about vector addition and subtraction in physics
  • Explore the concept of electric fields between capacitor plates
  • Investigate the behavior of charged particles in electromagnetic fields
Students studying electromagnetism, physics educators, and anyone interested in the dynamics of charged particles in electric and magnetic fields.
lynkyra
Let E = 4 N/C in the x direction and B = 4 T in the -z direction. Let an electron move in the y-direction
with speed 1m/s. What is the magnitude of the acceleration of the electron in m/s2?
Fm=qv X B
Felectric field=qE
F=ma
I plugged in values and found Fm to equal -6.408X10-19N and found Felectric field to also equal -6.408X10-19N. I'm not sure my sign is right on the first one because I was confused about the flow of the electron versus the flow of the current...
F=ma, and since I know the mass of an electron and I'm trying to find the acceleration, I think that I should add my two forces to get a total force, which equals ma. I did this and got a=4.508X10-7. I think this is wrong, though, because I think an acceleration would be larger than that.
Yes, check your signs. The directions of the forces are key. When in doubt, set up the vectors (they're very simple in this case) and carry out the vector math to find the resultant force. You may find that the net acceleration is smaller than you think :wink:
I would check my signs, but I don't know what they should be. I'm not good with vectors and I don't fully understand what a cross product is. Also, my instructor implied that the answer to this question was only X10^-(1,2, or 3).
A negatively charged electron is accelerated "upstream" in an electric field. Remember that when you draw a diagram showing an electric field, the field arrows are shown emanating out of positive charges and into negative charges (think of the electric field between capacitor plates). A negative charge is attracted by a positive charge. So the electron heads "against" the arrow directions. On the other hand a positive charge does the opposite and accelerates in the same direction as the field arrows.
For magnetic fields you should learn to use the right-hand rule to find the direction of the force. The right-hand rule tells you the direction that results from performing a cross product of vectors (in this case velocity crossed with magnetic field). Comes in very handy (pun!) in many situations where cross products come up.
  • · Replies 25 ·
