Acceleration on a curve for a car
When a car accelerates on a curve, it can tilt outward due to the balance of forces, despite centripetal force acting inward. The discussion highlights that friction provides the necessary centripetal force, while the side force can be considered as an "effective" centrifugal force. The calculations aim to determine the maximum tangential acceleration of the car, factoring in the maximum side force without specific speed or radius values. The method involves calculating resultant forces and ensuring they do not exceed the frictional force available. The complexity increases when the car does not maintain a constant speed, requiring careful consideration of static friction and the dynamics of acceleration.
ahchonx
As we know, if a car accelerate on curve at certain speed, it will tilt outside the circle track. So i sketch this 2 picture to show how (for me) it works.
http://img193.imageshack.us/img193/2323/66057246.jpg
http://img194.imageshack.us/img194/9272/96495741.jpg
I just wondering, how can the car tilt or flip outside the circle track if the side force (centripetal force) is pointing inside the circle?
My suggestion:
Total Moment about tyre (2); ∑M2=0
So, Fs*h + G*b/2 - FN1*b = 0
I assume that FN1=0 since the car is about to tilt about tyre (2). So here come the problem.
Fs = - G*b / 2h.
The minus sign shows that the side force, Fs, should point outside the circle.
Any comments?
Thanks LowlyPion.
So, what I understand from the link u gave me, the friction force should be act towards the centre of the circle and the side force towards outside?
In other words, friction = centripetal and side force = centrifugal ("effective") force?
Hi there,
You might want to forget about centrifugal force in your equations, since it is an imaginary force. The equation of a car winding around a curve, at a constant speed, would looke more like this:
\sum F = ma_{cent}
\text{friction} = m \frac{v^2}{R}
Cheers
Thanks fatra2,
The main purpose for me doing this calculation is to get maximum tangential acceleration of the car, since the car is not traveling on the curve with constant speed.
For that, I need to calculate first the maximum side force Fs (the speed and radius is not given). So I use this method to determine the maximum side force without taking the speed and the radius into account.
After I get the side force Fs, I add it to F1 to get the resultant force.
Fres = √(〖F_1〗^2+〖Fs max)〗^2 )
And then, the resultant force should be equal or less than the friction force in x and y-axis (in the picture above, the yellow circle indicate that firction).
Fres ≤ F_μH
(m.a)^2+〖Fs max)〗^2 ≤〖F_μH〗^2
F_μH and m are known. Fs max is also known from the previous calculation. Hence, I get the maximum acceleration,
a_max = √(〖F_μH〗^2-〖Fs max〗^2 )/m
Is my method correct?
Hi there,
If the speed of the car is not constant, the problem gets more complicated. The basic equation stays the same:
\sum \vec{F} = m \frac{d^2\vec{r}(x,y)}{dt^2}
For which the friction will act in both direction (x,y). Since the car accelerates, the motor develop traction on the wheels, which in turn develop backward friction on the road, which makes the car go forward.
I guess you don't want to have the car spinning and skidding on the road, so you can assume only static friction. But the value f=\mu N gives the maximal scalar value of the friction. If the case is where you are far from spinning and skidding, then the value can take a lower value than that.
I am sorry to complicate your porblem, but if you want to have a correct solution, you should not overlook anything. Cheers
