Acceptable misalignment between holes on mating parts?
  • Thread starter Thread starter Steven9
    Holes parts
A design involving a stack of CSK PC/104 PCB boards has a 0.1mm misalignment in screw holes for HEX spacers, which raises concerns about assembly. The holes are M3 clearance, and the drill size used was 3.3mm, allowing for a positioning tolerance of ±0.150mm. This suggests that the misalignment is likely acceptable and should not pose significant issues during assembly. Participants in the discussion agree that as long as tolerances do not compound negatively, the assembly should work. Overall, the situation appears manageable with the given tolerances.
Steven9
Hi,
I am working on a design that has a stack of CSK PC/104 pcb boards fastened togther using HEX spacers.
One of the PCB boards is being designed by an different design team. They have already manufactured their board but it turns out that the screw holes for the Hex spacers are mislaigned to the board that it will be fastened to by 0.1mm.
The holes are M3 clearance. Does anyone Know if this will cause a problem during assembly? Is 0.1mm an acceptable misalignment? I believe normal PCB manufacturing tolerance is 0.075mm
Thanks,
Steven
It depends on the drill size that was called out, if it was 3.3 mm, then it will probably be fine.
Thanks MRFMengineer, its was a 3.3mm drill size that was called out.
So, that gives you +-0.150 mm positioning tolerance, so as long as the engineering gods did not stack up all the tolerances against you, it should work.
Yeah, hopefully we will get a bit of luck! Thanks, for your comments...things a bit clearer now!
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
