What is the significance of the equivalence point in acid and base titrations?
The equivalence point in acid-base titrations is significant as it represents the moment when the amount of titrant added exactly neutralizes the analyte, typically indicated by a steep slope on the pH curve. Initially, when a strong base is added to a strong acid, the pH changes minimally due to the lack of buffering capacity in that region. The ideal equivalence point occurs at an inflection point, where the second derivative of pH with respect to volume is zero, although this is rarely achieved in practice. Understanding these concepts is crucial for accurately interpreting titration curves and determining the endpoint of titrations. The discussion highlights the complexities involved in real-life titration scenarios.
Scharles
http://img19.imageshack.us/img19/2692/chptitration.jpg
http://img130.imageshack.us/img130/6351/titrationfigure1.jpg
1.)For the titration of strong acid and strong base, and at the beginning of the curve, how to explain the big amount of base added only increase a little of the pH value since it was not a buffer region.
2.)The line of point S or equivalence point is a straight line or steep/slope to left hand side ??
thanks~~
The equivalence point occurs ideally when at an inflection point. That is when slope reaches a extremum (want \frac{d^2(pH)}{dV^2} = 0) - however I have found that rarely happens in real life - you want the point closest to where this is true.
I am still thinking about the first part.
