Is the Combined Solution Acidic or Basic?
  • Thread starter Thread starter Zoey Brown
When mixing 250ml of 1.5M HCl with 150ml of 2.0M Ba(OH)2, the limiting reactant is Ba(OH)2, resulting in 0.3 moles of BaCl2 produced. To determine whether the combined solution is acidic or basic, one must calculate the moles of HCl and Ba(OH)2 and analyze the reaction products. The reaction between HCl and Ba(OH)2 will produce water and BaCl2, with the remaining HCl indicating the solution's acidity. The excess HCl will lead to a final solution that is acidic. Therefore, the combined solution is acidic due to the presence of unreacted HCl.
Zoey Brown
A student has 250ml of 1.5M HCl and 150ml solution of 2.0M Ba(OH)2. When he mixes the 2 together, is the combined solution acidic or basic?
n=cv
ph=-log[h]
the limiting reactant is Ba(OH)2. it is .3 moles which means bacl2 will also be .3 moles
Which reactant is in excess?
Change each quantity to moles. Write the reaction. Use ratios according to the written reaction and compare to the moles you started for each reactant.
H'm yes, but moles of what? When he writes the reaction as you suggest he may well see that it's not the moles of "Ba(OH)2 or of Ba that most matter. :oldwink:
BOTH of them
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
