Active cell balancing with LTC3300-2
  • Thread starter Thread starter Reynald
    Cell
3 replies · 3K views
Reynald
Hi everyone good day to all who will read this!
We have a project about active cell balancing that will be put inside an electric-car. We are planning to use LTC3300-2 IC that can perform charge transfer. However, our question is that, How to choose the right microcontroller for our project considering we are about to create 6cells in a stack, and it must be stackable. Also we want to ask for guidance in implementing the connection between the chosen microcontroller and LTC3300-2. And if we want to stack another LTC3300-2 two extend the capacity of the cell balancer, how can we do that? Any advice even a little bit will be much appreciated, Thanks and god bless everyone have a nice day!
jim hardy said:
I never used one of those
but the datasheet and appnote look pretty self explanatory
http://cds.linear.com/docs/en/datasheet/33002fa.pdf
http://cds.linear.com/docs/en/lt-journal/LTJournal-V23N1-01-df-LTC3300-1-Drew.pdf
and if i read them right the -1 might be better adapted to stacking . Will you have more than 36 volts ?You'll learn fastest by doing
patch together an experimental one to learn its tricks.
thank you for answering, our plan for 1 stack is about 6cells = 24volts and we need 2 stacks so it will be about 48volts in total when we stack another 6cells. overall it will be 12cells. Thank you, much appreciated.
i'd be talking through my hat if i claimed any expertise.
Last one i used was a Domino-II by Micromint about fifteen tears ago. I chose it because we had 5 days to get a project going, including ordering the parts. The Domino you program in Basic so there was no learning curve to stumble up. The company was small enough then i got personal help from its founder.
I used both its serial(RS232) and I2C communication ports, and a few bits of parallel I/O .
I recently bought an Arduino just to see what they're about. Its language i found harder to learn than Basic
but it's compiled so runs many times faster.
I'd advise pick one that'll likely still be around twenty years from now. Your first one is hardest to learn.
I;d probably look at Texas Instruments just because of who they are. And at Micromint because they're still growing and have a heritage of practicality..
But I'm way back in the dust behind the young folks on this subject. Ask some hobbyists in your outfit.
Sorry can't do more
old jim
