Active pull/push,open collector,three state
  • Thread starter Thread starter beserk
    State
Active pull/push, open collector, and tri-state outputs are fundamental concepts in electronics. Push-pull outputs can drive a pin high or low, allowing current to flow in either direction, but connecting multiple outputs can cause conflicts. Tri-state outputs can be disabled, enabling multiple outputs to share a connection without interference. Open collector outputs only pull current in, requiring a pull-up resistor to function properly, which avoids conflicts without additional logic. "The Art of Electronics" by Horowitz and Hill is recommended as a comprehensive resource for understanding these concepts.
beserk
I'm a mechanical engineer starting with electronics.I am unable to understand concepts like pull\push, open collector, tristate etc.
Please help me with tips,links,books etc.
Nomally the output of a logic chip is a one or a zero and this is done by
making the pin on the chip present a high or low voltage. This is push-pull.
Depending on what you connect to the pin, current could flow either
into or out of the pin for either a one or a zero.
Also, you would never want to connect two outputs together because
they could fight each other.
A tri-state output can be "opened-up" under logic control so it looks
like the pin has been disconnected from the chip. This let's you connect
several outputs together in a way where the logic can decide which of
them is doing the outputing. It's a push-pull with a disable feature.
Open collector is when it's only pull, not push. The pin can only pull
current into it, it's can't push current out. This let's you connect
several outputs and they won't fight but you don't have to have
any disable logic. There is usually something called a "pull-up resistor"
to replace the missing transistor in a push-pull arrangement.
Sorry if I'm starting to sound like a broken record here, but this is the best intro to electronics book I've found -- really good at several levels from basic up through intermediate:
Amazon:
I can pretty much guarantee that you won't be disappointed by this book. Check it out in your library first if you want before buying it.
Great explanation by Antiphon, BTW.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
