Adding a remote switch to my electric scooter
10 replies · 3K views
Hannemaster
Hi Guys,
Im totally new here and I'm not even sure if this is the right forum, but I think there are a lot of people here who know all about electronics.
Ok so I bought an electric scooter. It has an on/off switch but no kind of security. So if I hook it up to a pole and leave, people can still turn it on. That's why I want a remote on/off switch which would allow me to disable the builtin switch. The top of the steering tube is quite easily removed which expose the on/off switch wiring.
this is the switch I was thinking about: remote switch they say the receiver works on 10-14V.(DC)
Now the scooter has a huge combination of batteries in it (3.6V ICR18650-M26 2600mAh Max 10A) and the specs say it has a battery charge limit of 42V. Now I don't think all that juice will flow through the builtin switch(will check with a multimeter soon. But what do I need if the voltage is lower or higher than the recommended 10-14V?
also the standby current is < 5MA, am I correct this is practically nothing?
so question 1: what to do when voltage doesn't match recommended receiver voltage?
questions 2: is a RF signal able to go through 1 or 2mm aluminum?
question 3: Am I correct that I won't even notice the standby current usage after a few hours?
question 4: if nobody tells me I'm crazy or stupid to even try this can someone guide me through which ports on the receiver I need to connect what. (yes I know where + and - goes but I don't really get the NC/COM/NO.
Hannemaster said:
Hi Guys,
Welcome to the PF.
Why not just replace the simple switch with a locking switch? What does the current simple switch look like?
http://plywoodchair.com/wp-content/...ck-Replacement-Amusing-Design-Garage-Door.jpg
Mount a battery switch close to the battery - I would use a switch like this (meant for boats):
Then your existing switch does all it is supposed to do, but you can disable everything with the battery switch.
This could be worth while taking into account if you intend to leave the device working for extremely long periods but a 10Ah battery would allow 10/5e-3 hours of operation (=2000hours). It's always worth doing the sums.
Thanks!
View attachment 147061Then your existing switch does all it is supposed to do, but you can disable everything with the battery switch.
That would be an option if the design was not this clean and if there was room for something like this. That's why I want a remote. So it won't be visible and ruin the clean modern look. Thanks for your reply though!
Is there any place to hide a switch? Only you would know about it.
You can always beat the thieves by doing something non-standard. A magnet-operated switch underneath a plastic part of the body would be hidden and not easily found even after taking it all apart. No thief would consider carrying a magnet around on a thieving trip.
well the only place I can think of is inside the steering tube. That's why I was thinking about a remote rf or something like that.
that's actually a really good idea! I'll do some research about these kind of switches.
The problem with trying to secure a small bike is that a pair of bolt croppers can deal with any chain you could carry with you and it can be lifted into the back of a truck by two burly felons.
Best to have an old scruffy one that no one would want.
true. The reason I want to lock it because I want to go into the city and when I go into a shop I'll leave it there for like 10min, would be nice if I could just remove a magnet or switch. I won't leave it there for long or overnight.
