Managing Newborns in a Hospital Nursery
  • Thread starter fishturtle1
  • Tags
    Elements
In summary: System.out.println(nursery.nameList()); }}In summary, the Nursery class contains an ArrayList to store Newborn objects. The add method adds a Newborn object to the end of the ArrayList. The remove method removes the first Newborn object with the given name from the ArrayList. The contains method determines if a Newborn with the given name is in the ArrayList. The nameList method gets an ArrayList of the Newborn's names in the Nursery.
fishturtle1
394
82
Now we are going to use the design pattern for collecting objects. We are going to model a hospital nursery filled with newborn babies. A Nursery uses an ArrayList to keep track of Newborn objects. You will write both a Nursery class and a Newborn class.
A Newborn has a name and a length. Provide a constructor that takes name and length, in that order. Provide getters and setters for the instance variables. This is the design pattern for managing properties of objects.
A Nursery has a constructor that takes no parameters. Remember it must initialize the instance variable
It has methods
  • add() Adds the specified Newborn to the Nursery
  • remove() Removes the first Newborn in the list with the specified name.
  • contains() determines if a Newborn with a given name is in the Nursery. Returns true if a Newborn with that name is in the Nursery. Otherwise false.
  • nameList() gets an ArrayList names of the Newborn in the Nursery.
Provide Javadoc for both classes.
We went over static methods and variables and constants before this lesson.
Code:
import java.util.ArrayList;
public class Nursery
    private ArrayList<Newborn> nursery;
    public Nursery()
        nursery = new ArrayList<>();
     * @param n the newborn object to be added to the end of the nursery array.
    public void add(Newborn n)
        nursery.add(n);
    public void remove(String target)
        boolean found = false;
        int i = 0;
        while(!found && i < nursery.size() - 1)
            if(nursery.get(i).getName().equals(target))
                nursery.remove(nursery.get(i));
                found = true;
            else
                i++;
    public boolean contains(String target)
        for(Newborn n : nursery)
            if(n.getName().equals(target))
                return true;
        return false;
    public ArrayList<String> nameList()
        ArrayList<String> storage = new ArrayList<>();
        for(Newborn n : nursery)//for each newborn in nursery
            storage.add(n.getName());//add their name to storage...it only adds the first name each iteration
        return storage;//return storage
My problem so far is that in my add method, whenever I add a Newborn object, it replaces any previously stored objects in the nursery instance variable with whatever I'm trying to add. Here is the tester with the results to show what I'm talking about;
Code:
 * Tester for Nursery
public class NurseryTesterFinal
    public static void main(String[] args)
        Nursery nursery = new Nursery();
        nursery.add(new Newborn("Lin", 17.4));
        nursery.add(new Newborn("Taran", 21.75));
        nursery.add(new Newborn("Sarah", 19));
        nursery.add(new Newborn("Miguel", 18.1));
        nursery.add(new Newborn("Sarah", 20.2));
        System.out.println("Expected: [Lin, Taran, Sarah, Miguel, Sarah]");
        nursery.remove("Sarah");
        System.out.println("Expected: [Lin, Taran, Miguel, Sarah]");
        nursery.remove("Lin");
        System.out.println("Expected: [Taran, Miguel, Sarah]");
        nursery.add(new Newborn("Aruna", 17.80));
        System.out.println(nursery.contains("Sarah"));
        System.out.println("Expected: true");
        System.out.println(nursery.contains("Kellan"));
        System.out.println("Expected: false");
        System.out.println("Expected: [Taran, Miguel, Sarah, Aruna]");
Code:
[Sarah, Sarah, Sarah, Sarah, Sarah]
[Sarah, Sarah, Sarah, Sarah]
false
Expected: true
false
Expected: false
[Aruna, Aruna, Aruna, Aruna, Aruna]
Any advice on how to fix the add method?
Somehow, instead of using an <Newborn>ArrayList, I used a <String>ArrayList.
my new code looks like this
Code:
    private static ArrayList<String> nurseList;
    public Nursery()
        nurseList = new ArrayList<>();
     * @param n the newborn object to be added to the end of the nurseList array.
    public static void add(Newborn n)
        nurseList.add(n.getName());
and now it works. I'm really confused as to why this works when I use a string array list but not a Newborn array list.
I don't have a Java system installed, so I can't test what I think is going on. In your code for the Nursery class, there is only one data member -- an ArrayList whose underlying type is Newborn. You don't show where this Newborn class is declared.
Your constructor for a Nursery object should specify the underlying type for the ArrayList it allocates, something like this:
Java:
public Nursery()
        nursery = new ArrayList<Newborn>();
The net effect of this, I believe, is that when you first create an empty nursery object, your add() method doesn't work correctly, because your Nursery constructor isn't creating the right kind of ArrayList.
Java:
public Nursery()
Thank you for the response. I may have misinterpreted something you said;
Code:
    private ArrayList<Newborn> nurseList;
    public Nursery()
        nurseList = new ArrayList<Newborn>();
        nurseList.add(n);
Here is also my Newborn class, sorry I forgot to include it.
Code:
 * construct a newborn object and have various methods to get and change
 * variables in the constructor
public class Newborn
    private static String name;
    private static double length;
     * @param n is the name of the baby
     * @param l is the length of the baby
    public Newborn(String n, double l)
        name = n;
        length = l;
     * @return the name of the baby
    public String getName()
        return name;
     * Let's you set a new name for the baby
     * @param aName the new name of the baby
    public void setName(String aName)
        name = aName;
     * @return the length of the baby
    public double getLength()
        return length;
     * Let's you change the length of the baby
     * @param aLength new length of the baby
    public void setLength(double aLength)
        length = aLength;
The tester still returns the same array of [Sarah, Sarah, Sarah, Sarah, Sarah] and similar to the other attempts to add.
but when I change the instance variables in my Newborn class to this
Code:
    private String name;
    private double length;
and put the Nursery class as you suggested, the tester passes every test. I'm not sure why the them being static variables made it output what it did.Edit: just looked at the lecture from few days ago, it said that creating static variables is almost never a good idea.. and I guess that's what I did.
First version:
Java:
New version:
Java:
Making the name and length members of the Newborn class static means that all instances of the Newborn class share the same string (and length). When you create new Newborn instances with your earlier version, the new instances overwrite the name and length members.
Mark44 said:
First version:
Java:
New version:
Java:
Thank you, that makes it clear what was happening.
I didn't explicitly say it, and I think you get it, but it won't hurt to add this -- by removing the "static" storage class from the name and length members, each Newborn instance now has its own unshared name and length data member.
FAQ: Managing Newborns in a Hospital Nursery
What is an arrayList?
An arrayList is a data structure in Java that allows for the storage and manipulation of a collection of elements. It is similar to an array, but with additional functionalities such as resizing and dynamic insertion and deletion of elements.
How do I add elements to an arrayList?
To add elements to an arrayList, you can use the add() method. This method takes in the element you want to add as a parameter and inserts it at the end of the arrayList. You can also specify the index at which you want to insert the element, using the add(int index, Object element) method.
What happens if the arrayList is already full when I try to add an element?
If the arrayList is already full, the add() method will automatically resize the arrayList to accommodate the new element. The new size of the arrayList will be double the previous size by default, but you can also specify a custom size to resize the arrayList to.
Can I add multiple elements to an arrayList at once?
Yes, you can add multiple elements to an arrayList at once using the addAll() method. This method takes in a collection of elements as a parameter and adds them to the end of the arrayList in the order they are in the collection.
How do I insert an element at a specific position in the arrayList?
You can insert an element at a specific position in the arrayList using the add(int index, Object element) method. This method takes in the index at which you want to insert the element and the element itself as parameters. The existing elements at and after the specified index will be shifted to make room for the new element.
