Addition of angular momenta
1 reply · 2K views
alebruna
TL;DR
Theoretical exercise on the addition of an angular momentum operator and a spin operator, derivation of eigenvalues and basis. Normalization of the eigenstates.
While studying for my exam I came across the addition of two angular momenta, in the simple case of ##J=L+S## where ##L## is the angular momentum operator and ##S## is the spin (in this case a fermion with ##s=1/2##). I have some doubts on the derivation of the basis and the eigenvalues.
From the start we know that ##J=L+S## and by this ##J^2=(L+S)^2##. We should start by the commutator ##[J_m,J_n]##
[J_m,J_n]=[L_m+S_m,L_n+S_n]=[L_m,L_n]+[S_m,S_n]=i\hbar\epsilon_{jmn}L_j+i\hbar\epsilon_{jmn}S_j=i\hbar\epsilon_{jmn}(L_j+S_j)=
=i\hbar\epsilon_{jmn}J_j
that shows that $J$ is still an angular momentum. By this we know that all the properties holding for both ##L## and ##S## apply also for ##J##, for example: ##[J,J^2]=0##.
Now we can study the commutators ##[J_m,L_n],\ [J_m,L^2],\ [J_m,S_n],\ [J_m,S^2],\ [J^2, L_n],\ [J^2,S_n],\ [J^2,L^2],####\ [J^2,S^2]##:
[J_m,L_n]=[L_m+S_m,L_n]=[L_m,L_n]\neq 0
[J_m,L^2]=\sum_n [J_m, L_n^2]=\sum_n\left( L_n[J_m,L_n]+[J_m,L_n]L_n\right)=\sum_n (i\hbar\epsilon_{jmn}L_n L_j+i\hbar\epsilon_{jmn}L_j L_n)=...=0
[J_m,S_n]=...\neq 0
[J_m,S^2]=...=0
[J^2,L_n]=[L^2+S^2+2L\cdot S,L_n]=[L^2,L_n]+\sum_m[L_m,L_n]=0+i\hbar\epsilon_{jmn}L_j\neq 0
[J^2,S_n]=...\neq 0
[J^2,L^2]=[L^2+S^2+2L\cdot S,L^2]=[L,L^2]\cdot S=0
[J^2,L^2]=...=0
Since ##J^2,\ J_m,\ L^2,\ S^2## all commute, for the third theorem of hermitian operators they feature a common base of eigenstates. Since ##J## has the form of an angular momentum we can assume that ##J_3## is associated to an eigenvalue ##\hbar m_j## and ##J^2## is associated to an eigenvalue ##\hbar j(j+1)##.
Hence the basis associated to operators ##J_m,\ J^2,\ L^2,\ S^2## is in Dirac notation: ##|j, m_j, l, s\rangle##.
About the properties of the eigenvalues:
J_3\left|j, m_j, l, s\right\rangle=(L_3+S_3)\left|j, m_j, l, s\right\rangle=(\hbar m+\hbar m_s)\left|j, m_j, l, s\right\rangle=\hbar m_j \left|j, m_j, l, s\right\rangle \rightarrow m_j=m+m_s
J^2\left|j, m_j, l, s\right\rangle=\hbar^2j(j+1)\left|j, m_j, l, s\right\rangle \ \text{with}\ j>0 \\
L^2\left|j, m_j, l, s\right\rangle=\hbar^2l(l+1)\left|j, m_j, l, s\right\rangle \\
S^2\left|j, m_j, l, s\right\rangle=\hbar^2s(s+1)\left|j, m_j, l, s\right\rangle \\
\rightarrow l-s< j<l+s
also ##-j\leq m_j\leq j##
We can see that the new basis of eigenvalues features a degeneracy for ##m+1,\ s=1/2## and ##m,\ s=-1/2## this means that the new basis can be written as
\left|j, m_j, l, s\right\rangle=\sum_{m,m_s}^\ast C(m,m_s)\left|l,m\right\rangle \left|s,m_s\right\rangle
The superscript * means that ##m+m_s## is constant.
Using spectrum generating algebra we can define ##J_+=L_++S_+## and ##J_-=L_--S_-##.
J_+\left|l,l\right\rangle\left|s,\frac{1}{2}\right\rangle=0 \\
J_-\left|l,-l\right\rangle\left|s,-\frac{1}{2}\right\rangle=0 \\
Taking the two states ##j=l+1/2## and ##j=l-1/2## can give us the coefficients for the double series.
\begin{cases}
\left|l-1/2, m_j, l, s\right\rangle=\alpha_-\left|l,m_j-1/2\right\rangle \left|s,1/2\right\rangle+\beta_-\left|l,m_j+1/2\right\rangle \left|s,-1/2\right\rangle \\
\left|l+1/2, m_j, l, s\right\rangle=\alpha_+\left|l,m_j-1/2\right\rangle \left|s,1/2\right\rangle+\beta_+\left|l,m_j+1/2\right\rangle \left|s,-1/2\right\rangle
\end{cases}
Normalizing gets us that
\alpha_\pm=\pm\sqrt{\frac{l\pm m_j+1/2}{2l+1}}=\pm\beta_\mp
This should conclude the derivation. Is this exercise correct? If not can anyone point out how this is wrong and why?
Some source material I found online are linked below.
\textbf{1. Angular Momentum and Spin Operators:}
You correctly started from the fact that you have two angular momentum operators:
\mathbf{L} \quad \text{(orbital angular momentum)}, \quad \mathbf{S} \quad \text{(spin angular momentum)},
and you define the total angular momentum operator as
\mathbf{J} = \mathbf{L} + \mathbf{S}.
Because both \(\mathbf{L}\) and \(\mathbf{S}\) satisfy the angular momentum commutation relations,
[J_i, J_j] = i \hbar \epsilon_{ijk} J_k,
it follows that \(\mathbf{J}\) also behaves like an angular momentum operator.
\textbf{2. Commutation and Common Eigenbasis:}
You mentioned studying the commutators involving \(J^2\), \(L^2\), and \(S^2\):
[J^2, L^2] = 0, \quad [J^2, S^2] = 0, \quad [L^2, S^2] = 0.
Since these operators commute pairwise, they can share a common eigenbasis. This is essential in constructing the joint eigenstates of these observables.
\textbf{3. Quantum Numbers and Dirac Notation:}
The standard notation for the joint eigenstates of \(J^2\) and \(J_z\) is
|j, m_j\rangle,
where \(j\) is the total angular momentum quantum number and \(m_j\) is its projection along the \(z\)-axis.
Similarly, the eigenstates of \(\mathbf{L}^2\) and \(L_z\) are
|l, m_l\rangle,
and for \(\mathbf{S}^2\) and \(S_z\),
|s, m_s\rangle.
For a spin-\(\frac{1}{2}\) particle (like a fermion), \(s = \frac{1}{2}\) and \(m_s = \pm \frac{1}{2}\).
\textbf{4. Addition of Angular Momenta:}
When combining \(\mathbf{L}\) and \(\mathbf{S}\), the possible total angular momentum quantum numbers \(j\) satisfy
j = |l - s|, |l - s| + 1, \ldots, l + s.
For example, if \(l = 1\) and \(s = \frac{1}{2}\), then \(j\) can be \(\frac{1}{2}\) or \(\frac{3}{2}\).
This gives the \emph{degeneracy} you mentioned: multiple \(m_j\) values correspond to each \(j\).
\textbf{5. Basis Transformation and Clebsch-Gordan Coefficients:}
The original basis is the \emph{uncoupled} basis:
|l, m_l\rangle |s, m_s\rangle,
where angular momenta are considered separately. The new basis after addition is the \emph{coupled} basis:
|j, m_j; l, s\rangle,
which are eigenstates of \(\mathbf{J}^2\) and \(J_z\).
The transformation between these two bases is given by the Clebsch-Gordan coefficients \(C^{j,m_j}_{l,m_l;s,m_s}\):
|j, m_j; l, s\rangle = \sum_{m_l, m_s} C^{j,m_j}_{l,m_l;s,m_s} |l, m_l\rangle |s, m_s\rangle.
These coefficients can be found in tables or calculated using standard recursion relations.
\textbf{6. Spectrum Generating Algebra and Ladder Operators:}
You also correctly introduced the ladder operators:
J_\pm = J_x \pm i J_y,
which raise or lower the \(m_j\) value by one:
J_\pm |j, m_j\rangle = \hbar \sqrt{j(j+1) - m_j(m_j \pm 1)} |j, m_j \pm 1\rangle.
The use of ladder operators is fundamental in constructing the entire multiplet of states starting from the highest weight state \( |j, j\rangle \).
\textbf{7. Normalization:}
The normalization condition
\langle j, m_j; l, s | j, m_j; l, s \rangle = 1
ensures that these states form an orthonormal basis. When constructing states via Clebsch-Gordan coefficients, the coefficients themselves satisfy orthogonality and normalization relations ensuring this.
\textbf{8. Is the Exercise Correct?}
Your exercise and derivation are essentially correct and follow the standard textbook approach for adding angular momenta in quantum mechanics. The key points are:
\begin{itemize}
\item Verify the commutation relations hold for \(\mathbf{J}\).
\item Identify the allowed \(j\) values.
\item Understand the transformation between uncoupled and coupled bases via Clebsch-Gordan coefficients.
\item Use ladder operators to generate all states.
\item Normalize states properly.
\end{itemize}
Your summary touches on all of these points appropriately.
\textbf{Additional Suggestions:}
If you want to deepen your understanding, I recommend:
\begin{itemize}
\item Reviewing a detailed example, e.g., adding \(l=1\) and \(s=1/2\).
\item Studying explicit Clebsch-Gordan tables.
\item Working through problems that require expanding states in both bases.
\item Consulting standard textbooks such as Sakurai's \emph{Modern Quantum Mechanics} or Cohen-Tannoudji's \emph{Quantum Mechanics}.
\end{itemize}
