Adjoint operators and diffeomorphism
mnb96
Hello,
we known that for each linear operator \phi:\mathbb{R}^n\rightarrow \mathbb{R}^n there exists an adjoint operator \overline{\phi} such that: <\phi(\mathbf{x}),\mathbf{y}>=<\mathbf{x},\overline{\phi}(\mathbf{y})> for all x,y in ℝn, and where <\cdot,\cdot> is the inner product.
My question is: can we give an analogous definition of adjoint operator when \phi:\mathbb{R}^n\rightarrow \mathbb{R}^n is a diffeomorphism of ℝn?
It's a pity that nobody answered to this question. Perhaps I did not formulate my question properly ... anyways, I will show a partial solution to the problem, and finally I will ask you if the result can be generalized.
Let's assume the diffeomorphism \phi is linear. Then we can write \phi(\mathbf{x})=A\mathbf{x}, where A is a n×n matrix. We have the well-known result that: \left\langle x,\; Ay \right\rangle = \left\langle A^T x, \; y \right\rangle Obviously in this case the adjoint of \phi is simply given by the transpose of the corresponding matrix A.
Note however that we can write: \left\langle A^T x, \; y \right\rangle = \left\langle (A^T A)A^{-1} x, \; y \right\rangle = \left\langle G A^{-1} x, \; y \right\rangle
I don't know if this is a useful step, but notice that G=A^T A is the metric tensor. The question now reduces to:
Does this result sill hold for "curvilinear" deformations, where \phi is a transformation of curvilinear coordinates, and G is the metric tensor expressed in terms of the Jacobian matrix?
Yes ##g = J^{T}J## where ##J## is the jacobian associated with ##\phi##.
Hi WannabeNewton,
thanks for your reply, and good to hear that the result holds for admissible change of coordinates.
Do you have any hint on what strategy I could use in order to prove this result?
I suppose that the result can be deduced from the knowledge of how the inner product in ℝn changes under a diffeomorphism given by a change of coordinates \phi:U\rightarrow \mathbb{R}^n, e.g. <\phi(u), \; \phi(v)> \; = \; ?
I asked online questions about Proposition 2.1.1: The answer I got is the following: I have some questions about the answer I got. When the person answering says: ##1.## Is the map ##\mathfrak{q}\mapsto \mathfrak{q} A _\mathfrak{p}## from ##A\setminus \mathfrak{p}\to A_\mathfrak{p}##? But I don't understand what the author meant for the rest of the sentence in mathematical notation: ##2.## In the next statement where the author says: How is ##A\to...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
