Affect of Temperature on Squash Balls experiment
5 replies · 6K views
iSasha
Hi there :)
I am currently preparing an experiment for IB physics, and I need some help planning how I'm going to carry it out.
We were given the topic "Balls and Rubber Bands", and we could choose freely upon the exact research question. I personally chose "How does the increase of temperature affect the bounciness of squash balls". My teacher approved this topic.
I currently plan to drop 5 different squash balls each time heated to the same, specific temperatures. After having dropped all five balls, I heat them up even more, and repeat the process.
None as of yet, I guess some basic maths calculations later on to find rebound height.
So, here are my questions:
- What is the safest maximum temperature I should heat them up to without destroying the balls? My best guess was around 50 °C.
- What is the best method to heat them up without damaging them? My best guess was to use a bunsen burner and heat it from the side.
- How do I measure the rebound height without using a motion sensor, photoelectric gate, or a laser trigger (according to my teacher, the equipment we have at our school is inadequate)? My best guess was a 1 meter ruler, however I don't see how I would be able to accurately record the rebound height without using technology...Any help would be appreciated. Nothing is set in stone as of yet, so I can still change around the experiment if you guys think that it will be a good idea. If you guys don't think that such a research question will yield a good grade, please tell me so. I would prefer if you guys helped me work it out instead of giving a straight answer like other homework help sites do.
Thanks!
Don't try to heat squash balls with a bunsen burner !
Accuracy can be improved by repeating results... it is not all down to technology
Thanks for the quick response technician!
Ok then, what can I use to heat up the balls, without damaging them?
Still, the experiment is really innacurate due to the fact that I will have to use my eyes to do the experiment. And I already am using multiple balls, and possibly multiple trials if I have enough time.
To help find the height of rebound try to arrange something called a 'fiducial' mark an adjustable stop of some kind that you can gauge the height with.
What is wrong with heating them in water... it is OK to heat the water with a bunsen burner... but care is still needed!
Great! Now, how do I use this? The only things I could find on google were related to prostate cancer and motion tracking. Sorry for being such a noob :/
Huh, I thought that water would damage them... BTW, I guess I'll try that.
Thanks again technician!
I hope this has got nothing to do with any kind of cancer!
If you are using a retort stand you could use a clamp and raise and lower it until you think you have it at the rebound height... make fine adjustments and you are then comparing the rebound height with a fixed mark... that is what is meant by a fiducial mark.
Heating in water will do a lot less damage than heating with a bunsen burner.
