Agebraic example of U-Substitution?
  • Thread starter Thread starter tomas
    Example
tomas
Could someone please show me a very easy agebraic example of U-Substitution?
Mathematics news on Phys.org
Solve the following indefinite integral:
∫(2x+1)3dx
There are actually two ways for us to solve this problem:
(1) Expand the integrand and the integrate the polynomial.
(2) Perform a u-subtitution.
The easier method is clearly the second and it's what you want to know how to do anyway.
We find a subexpression to set u equal to (in this case it is fairly obvious):
u = (2x+1)
Then we find the derivative of this subexpression:
du/dx = 2
We multiply and divide the integrand by this derivative as follows (note that this simply means multiplying by one):
∫(2x+1)3 * (du/dx)/(2) dx
∫(1/2)(u)3(du/dx)dx
If you remember the chain rule for derivatives, then you'll also remember that the derivative of f(u(x)) = f'(u(x))u'(x). Well, Our integrand is already in this form now. To find its antiderivative, we can ignore the u'(x) and integrate f'(u) (w/ respect to u) to find f(u) and then simply change the formula back to f(u(x)) to obtain the final antiderivative.
Following through with this we obtain:
∫(1/2)u3du
(1/8)u4
(1/8)*(2x+1)4
Well someone beat me to it but another example can't hurt. :smile:
Suppose you have:
[inte][2x(x2+ 1)]dx
You can solve this by u-substitution because if you let u = x2 + 1, then du = 2x.
[inte][u1/2]du = [(2u3/2)/3] + C
One thing about u substitution is that you should pick a u where du is in the integrand.
change of variable
I like to treat "dx"s and "du"s like factors in the equation. It makes the problem seem a lot more algebra-y, and people like algebra. Some people throw du's and dx's on then end because they know they should, not because they think it means something.
Anyway, here's a fun example.
[inte] xdx/(bx+a)
let u = bx+a
then, du=bdx
since no "bdx" exists in the integrand, you have to solve the equation for something that does, ie, dx
(In my math class, the teacher taught us to rewrite the integrand to make it fit the du/dx equation. I feel that it's a lot clearer to rewrite the du/dx equation to make it fit the integrand.)
dx=du/b
replace dx with du/b and bx+a with u
[inte] x(du/b)/(u)
since u=bx+a
x=(u-a)/b
replace x with (u-a)/b
[inte] [(u-a)/b](du/b)/(u)
From there, just a little algebra and you get:
1/b2[inte] (1-a/u)du= 1/b2[u-alnu]+C
Just in case anyone else falls upon this thread, i'll post one more problem.
(inte)(3x+4)^8 dx
u=3x+4
du=3dx
du/3=dx
plug your dx back into your original equation
(inte)(u)^8 (du/3)
1/3(inte)(u)^8 du
(1/3)(1/9)(u)^9 +c
(1/27)(3x+4)^9 + c
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
