Chosing air blowers to force air through a solar heat storage array
The discussion revolves around the design of a solar collector using rectangular hollow steel bars filled with gravel for heat storage, with the intention of preheating air for a gas combustion oven to reduce gas consumption. Participants inquire about the necessary airflow requirements, dimensions, and orientation of the system. There is a specific question about whether a normal fan can be used or if a blower is required for effective air movement. Additionally, the need for a dimensioned sketch of the proposed system is suggested to clarify the design. This conversation highlights the importance of airflow calculations and system specifications in optimizing solar heat storage solutions.
Salah
hi guys:
i plan to make solar collector using rectangular hollow steel bar 4×8cm filled with gravel as heat storage and blow air through it and direct that air as preheated for gas combustion oven to reduce gas consumption .can i use a normal fan or it has to a blower?
Welcome, @Salah !
Do you know how much air will need to flow through one of the hollow steel bars?
How long each?
Vertical or horizontal?
What size stone?
I am assuming that you will have some of those in parallel.
Can you upload a dimensioned sketch of your proposed system? That would help a lot, thanks.
(Use "Attach files" to upload a PDF or JPEG image)
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
