Air valve operated by permanent & electro magnet
The discussion centers on the design of a valve system that operates under low pressure conditions, utilizing a combination of permanent and electromagnets to facilitate the opening of lightweight valves. The user seeks to understand if a strong permanent magnet can effectively work against a weaker electromagnet to minimize current requirements, and whether an air core can be used for the electromagnet without excessive attraction to the permanent magnet. The valves are designed to drop down to allow air passage, and the terminology around "lift" in this context is clarified as a reference to air pressure. Participants suggest that an air gap can be maintained to control polarity and that practical experimentation with magnets and coils could provide insights. The overall goal is to create an efficient system for operating numerous valves with minimal energy consumption.
Wurlitzer28
I am looking to open a series of valves in a chamber under 10" of lift(water) ~.36psi which are normally held closed by a very light spring and the constant air pressure. The valves are very light weight and range in surface size from approx 2 to 6 sq inches, or approx .72 to 2.16 lb of initial force to begin opening them.
The valves offer the greatest resistance when closed so I need the greatest force to begin opening them but once they start to open the force drops dramatically to mainly the lightweight spring. The weight of the valve at this point actually aids in keeping it open as they are dropping down (hinged at one end). The travel of the free end of the valve surface would be approx 3/8".
My thought was to use a very strong permanent magnet situated in direct contact with an electromagnet such that when energized the two magnets would repel each other. This would create a force profile ideally suited to this application as the repelling force would drop as the two magnets moved away from each other and the required force to keep the valve open would also decrease.
QUESTION 1: Am I correct in assuming that I can leverage the strong force of the permanent magnet against a relatively weak electromagnet (so as to limit the current/turns required) OR will the repulsive force be closer to the weaker force of the electromagnet? If I cannot leverage the strong force of the permanent magnet this would not be a viable application.
QUESTION 2: Can an air core for the electromagnet suffice as the core of the electromagnet, IMO, cannot be iron less the permanent magnet would be so attracted to it as to require excessive current/turns to break that attraction.
The requirement for 1000s of these magnets in this application makes it imperative to minimize the current and to a lessor extent the amount of wire for each coil. These coils will have at most a 10% duty cycle and ideally run at approx 12vdc.
Toilet tank flush valves?
Wurlitzer28 said:
dropping down
You initially describe a valve being lifted against 10" water, and now you're dropping them; could you restate this?
These valves are rectangular pallet valves comprised of a light weight wood covered on their upper surface in felt and leather. They are hinged along one of the short ends of the rectangle.
They are mounted within a pressurized chamber with the leather surface facing up and when operated they must drop down to allow the air to pass upward through a hole in the top surface of the chamber.
The LIFT is a normal term (albeit old and antiquated IMO) used in industry to describe air pressure. Why it is still used?? That is why I gave the conversion to .36psi. Sort of like mercury used as a reference for vacuum. Just a way to confuse the issue. But then again I prefer CPS to Hertz. A 10" lift will raise a column of water 10".
The permanent magnet is going to look just like the armature of any solenoid to the electromagnet. Sorry.
Polarity of an iron core is controlled by the winding, and so long as you leave a gap, say thickness of your valve, you should be able to push neodymium magnets fastened to the flappers around at will.
You should be able to pick magnets up at a novelty shop for a couple bucks, and play with relay/solenoid coils and armatures as a test.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
