Finding the Domain of an Algebraic Function
  • Thread starter Thread starter NelsonsXanadu
    Function
The domain of the function f(x) = 2/(x + 3) is all real numbers except for -3, as this value makes the denominator zero and results in an undefined expression. The initial assumption that zero is excluded from the domain is incorrect; f(0) is defined and equals 2/3. The key point is to identify values that cause the denominator to be zero, which in this case is solely -3. Therefore, the correct domain can be expressed as all real numbers except -3. Understanding the function's behavior around its denominator is crucial for determining the domain accurately.
NelsonsXanadu
Find the Domain
f(x) = ___2___
x+3
I know this is a pretty simple question just want to make sure I'm on the right track. Wouldn't the domain be all numbers except zero? Because you can't divide by zero? How would I write this
NelsonsXanadu said:
Find the Domain
f(x) = ___2___
x+3
Another way to write this that is clearer is f(x) = 2/(x + 3)
No, 0 is in the domain, because f(0) = 2/(0 + 3) = 2/3.
Yes, you cannot divide by zero. What value of x makes the denominator 0?
Well a -3 would make the denominator 0...
So -3 is not in the domain. Are there any other values for which this function is undefined?
What you are looking for is for the *denominator* to not be zero, such that you don't divide by zero. And you're right in saying that -3 is not in the domain. Just make sure that -3 is the only thing that's not in the domain.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
