JavaScript Algorithm to return all subarrays of a given array
  • Thread starter Thread starter SlurrerOfSpeech
    Algorithm Array
The discussion centers around implementing a JavaScript function to generate all non-empty subarrays from a given array. The proposed method utilizes bit manipulation, leveraging the fact that for an array of n unique elements, there are 2^n possible subsets, including the empty set. By iterating through numbers from 1 to 2^n - 1, the algorithm checks each bit to determine whether to include each corresponding element in the subarray. The provided JavaScript implementation effectively constructs these subarrays and returns them in an array. Participants express interest in translating this logic into C++, with some seeking clarification on the underlying logic of the JavaScript code. The discussion emphasizes the simplicity of the approach while acknowledging the need for careful consideration when adapting it to C++ data types. There is also a mention of sorting the resulting subarrays by length, which could add complexity to the implementation.
SlurrerOfSpeech
I can't find this exact algorithm anywhere on the internet. What I'm trying to implement is the following function
Code:
// Returns all subarrays of the given array, not including the empty array
// ex. [a,b,c].subarrays() = [ [a], [b], [c], [a,b], [a,c], [b,c], [a,b,c] ]
Array.prototype.subarrays = function(...)
in a larger program I'm writing. (I know how to do it easily if the subarrays are contiguous sequences of the original array)
Also, if this makes things easier, in the single use case of my program the original array has unique items.
Technology news on Phys.org
Perhaps you can use the fact that for a list of n elements there are 2n sub-lists, including the empty one. For instance, if there is 8 elements, then if you iterate i from 1 to 256 then the each of the 8 bits for each value of i will tell whether or not to include the element corresponding to each bit.
Likes FactChecker and jim mcnamara
Filip's solution seems the most elegant to me.
You don't want the empty set i.e. the number ##(0000\,\, 0000)_2=(0)_{10}## isn't a part of the list you generate.
The first one would be ##(0000\,\, 0001)_2=(1)_{10}##, the second one ##(0000\,\, 0010)_2=(2)_{10}## and so on.
So it is a simple sequence ##1,2,\ldots ,256## that you have to relate to the correct subsets of your array.
E.g. right-most bit corresponds to "array[0]" and so on.
This won't give you an array of subarrays ordered by length of said subarrays so you might have to do a sorting step if you want this.
In that case the sorting is likely the most expensive part of the code (if you need to optimize the code sometime later on). Perhaps a specialized sorting algorithm can use the pattern found in the length of the generated subarrays.
Genius! I'm going to do that.
Worked beautfiully. Thanks!
This ended up being my implementation:
Code:
Array.prototype.subarrays = function()
   var subs = [];
   for(var i = 0, n = Math.pow(2,this.length); i < n; ++i)
      var sub = [];
      for(var j = 0; j < this.length; ++j)
          if (((i >> j) & 1) == 1)
              sub.push(this[j]);
        subs.push(sub);
   return subs;
Likes jim mcnamara and Pepper Mint
could someone give the code in c++?please
The JavaScript code is very easy to follow, if your knowledge of C++ is not sufficient to translate it then do you think you will to be able to use it?
Sorry but i don't know javascript and really didn't understood the logic either so if someone could share a C++ snippet it might would have Helped me out
Regarding the logic of the Javascript code in this thread it is really simple:
  1. Given is an array a of length n.
  2. For each i from zero to 2n do
    1. Set array sa = []
    2. For each j from zero to n do
      1. If the i has the j'th bit set then append a[j] to sa.
    3. Use sa for something.
Of course, if you go with implementing this in C++ then all of the above lines will give rise to considerations on how to map this onto C++ data types and similar.
Edit: removed my somewhat brain-farted recommendation for using std::next_permutation as this of course does permutations and not sampling.
