MHB All Possible Sortings of a DAG - Hello! (Wave)
  • Thread starter Thread starter evinda
The discussion revolves around finding all possible topological sortings of a Directed Acyclic Graph (DAG) using an algorithm based on an adjacency matrix. Participants explore various algorithmic approaches, including a recursive backtracking method that generates all valid orderings by maintaining a set of starting nodes and an output list. The conversation highlights the importance of ensuring that nodes are only added to the output list when their dependencies are satisfied. A key realization is that the initial algorithms proposed only yield a single topological sorting, while a backtracking approach is necessary to find all possible sortings. The final consensus is that the backtracking method is the correct way to achieve the desired outcome.
evinda
MHB
Hello! (Wave)
Suppose that we have a DAG and want to find algorithmically all its possible topological sortings.
I found this program at page 6: http://www.cs.ncl.ac.uk/publications/trs/papers/61.pdf, but I haven't really understood it.
Could you explain me the general idea?
How would it work for example if we had the following graph?View attachment 4228
Technology news on Phys.org
Also I thought that we could also find all the possible sortings with an adjacency matrix.
I have thought of the following algorithm:Let $S$ be the set of the starting nodes.
Code:
while (S!=empty set){
         pick a node q from S
         Alg(q)
Code:
Alg(q){
     for i=1 to |V|{
          if A(q,i)==1{ // A is the adjacency matrix
             A(q,i)=0
             Enqueue(Q,q)
             Alg(i)
     Dequeue(Q)
Is the general idea right? If so what could I improve at the algorithm? (Thinking)
I don't know about that paper, but I have an idea how to do it. (Thinking)
Suppose we repeatedly run through the nodes and pick the first node that has all incoming dependencies satisfied.
We'll append that to an output list that is initially empty.
In the first run nodes b and e are the only nodes that have no arrows pointing to them.
So we pick b as the first node and get the output list (b).
In the second run e is the only node available, yielding (b, e).
In the third run a has become available, since its dependency on e is now satisfied.
So we get (b, e, a).
Next is c. And finally we get to d.
So our list has become (b, e, a, c, d). (Happy)
To do this, could we use the adjacency matrix as I did in post #2? (Thinking)
evinda said:
Code:
         Alg(q)
Code:
Alg(q){
     for i=1 to |V|{
             A(q,i)=0
             Enqueue(Q,q)
             Alg(i)
     Dequeue(Q)
Let's see... (Thinking)
First node we might pick is q=a.
So we would execute Alg(a).
Searching the adjacency matrix, we find that a is connected to c.
So we remove that connection, we enqueue a, and continue with Alg(c).
But... node a is not suitable to select as first node. :eek:
I think I don't understand your algorithm.
Can you clarify? (Wondering)
$S$ is the set of starting nodes, that means it contains all the vertices with no incoming edges. So $a$ cannot be selected as first node. (Thinking)
Can you run through your algorithm then and explain how the nodes get processed? (Wondering)
I changed a little the algorithm.
Code:
S: set of starting nodes
L: output set
while (S != empty)
     pick a node q and delete it from S
     Alg(q)k=0;
Alg(q){
     add q into L
     for i=1 to |V| {
          if (A(q,i)==1){
               A(q,i)=0
               for j=1 to |V| {
                    if (A(j,i)==1)
                        k=k+1;
               if (k==|V|)
                    add i to S
               Alg(i)
At the beginning we have $S=\{b,e\}$. We pick $q=b$, delete it from $S$, so $S=\{e\}$.
We call [m]Alg(b)[/m] and we add $b$ into $L$, so $L=\{b\}$.
[m]A(b,d)==1[/m]
We set [m]A(b,d)=0[/m], $d$ has still incoming edges so we don't add it into $S$.
We call [m]Alg(d)[/m] and we add $d$ into $L$, so $L=\{b,d\}$.
The condition [m]A(d,i)[/m] is never satisfied so we go back at the while-loop.
We pick $q=e$, delete it from $S$, so $S=\{ \}$.
We call [m]Alg(e)[/m] and we add $e$ into $L$, so $L=\{b,d,e\}$.
[m]A(e,a)==1[/m]
We set [m]A(e,a)=0[/m], $a$ has no incoming edges so we add it into $S$, so $S=\{a\}$.
We call [m]Alg(a)[/m] and we add $a$ into $L$, so $L=\{b,d,e,a\}$.
[m]A(a,c)==1[/m]
We set [m]A(a,c)=0[/m], $c$ has no incoming edges so we add it into $S$, so $S=\{c\}$.
We call [m]Alg(c)[/m] and we add $c$ into $L$, so $L=\{b,d,e,a,c\}$.
The condition [m]A(c,i)[/m] is never satisfied so we go back at the while-loop and since $S$ is empty, we have finished.
Is it right? (Thinking)
But...can we find in that way all the possible topological sortings or only one? (Thinking)
[m]A(b,d)==1[/m]
Wait! (Wait)
You just said that $d$ still had incoming edges.
Doesn't that mean that it is too early to add it to $L$? (Wondering)
I like Serena said:
Wait! (Wait)
I changed again something..
Code:
L: output set
while (S != empty)
     Alg(q)
Alg(q){
     for i=1 to |V| {
          if (A(q,i)==1){
               A(q,i)=0
               Alg(i)
     add q into L
Now we get this output: [m] L={d,b,c,a,e} [/m]Is this output right? (Thinking)
Now I read that "The Floyd–Warshall algorithm compares all possible paths through the graph between each pair of vertices."
Could we take this into consideration in order to find all the possible topological sortings? (Thinking)
Node d has incoming arrows, so I don't think it should be first in the list. (Worried)
That seems to be an algorithm to find a shortest path.
How would that help to find a topological ordering? (Wondering)
I changed again the algorithm:
Code:
    L: output set
    while (S != empty)
         pick a node q, delete it from S and add it into L
         Alg(q)
    Alg(q){
         for i=1 to |V| {
              if (A(q,i)==1){
                   A(q,i)=0
              for j=1 to |V| {
                   if (A(j,i)==0){
                       k=k+1
              if (k==|V|){
                  add i into S
Now I get this output set: {b,e,a,c,d}.
But can we get in that way all the possible topological sortings? (Thinking)
Code:
    L: output set
    while (S != empty)
         Alg(q)
    Alg(q){
         for i=1 to |V| {
              if (A(q,i)==1){
                   A(q,i)=0
              for j=1 to |V| {
                   if (A(j,i)==0){
                       k=k+1
              if (k==|V|){
                  add i into S
Yep. I think so. (Nod)
Not really... you'll only find one possible sorting... (Wasntme)
To get all possible sortings, you'll need a backtracking algorithm. (Thinking)
The standard format of backtracking is:
Code:
Recurse()
	Create list of choices
	If no choices and solution found
		Output solution
	For each possible choice
		Execute choice
		Recurse()
		Undo choice
You can do that in your case for instance as follows:
Code:
    L: output set
    A: adjacency matrix
    Recurse()
    Recurse(){
         if S empty
            output L
         oldA = A
         oldS = S
         oldL = L
         // For each possible choice
         for each node q in S
             // Execute choice
             delete q from S and add it to L
             Alg(q)
             // Recurse
             Recurse()
             // Undo choice
             S = oldS
             L = oldL
             A = oldA
    Alg(q){
         for i=1 to |V| {
              if (A(q,i)==1){
                   A(q,i)=0
              for j=1 to |V| {
                   if (A(j,i)==0){
                       k=k+1
              if (k==|V|){
                  add i into S
Code:
Recurse()
		Output solution
		Execute choice
		Recurse()
		Undo choice
Code:
    L: output set
    A: adjacency matrix
    Recurse()
    Recurse(){
         if S empty
            output L
         oldA = A
         oldS = S
         oldL = L
             // Execute choice
             Alg(q)
             // Recurse
             Recurse()
             // Undo choice
             S = oldS
             L = oldL
             A = oldA
    Alg(q){
         for i=1 to |V| {
              if (A(q,i)==1){
                   A(q,i)=0
              for j=1 to |V| {
                   if (A(j,i)==0){
                       k=k+1
              if (k==|V|){
                  add i into S
I tried to execute the algorithm in order to understand it..
The set of starting nodes is: $S=\{b,e\}$.
The output set is $L=\{ \}$.
The adjacency matrix is the following: $$A:\begin{matrix}
& a & b & c & d & e & \\
a & 0 & 0 & 1 & 1 & 0 & \\
b & 0 & 0 & 0 & 1 & 0 & \\
c & 0 & 0 & 0 & 0 & 0 & \\
d & 0 & 0 & 0 & 0 & 0 & \\
e & 1 & 0 & 0 & 0 & 0 &
\end{matrix}$$
Code:
    Recurse()
       oldA=A
       oldS=S={b,e}
       oldL=L={ }
       q=b
       S={e}, L{b}
       Recurse()
           oldA=A
           oldS=S={e}
           oldL=L={b}
           q=e
           S={ }, L={b,e}
           S={a}
           Recurse()
               oldA=A
               oldS=S={a}
               oldL=L={b,e}
               q=a
               S={ }, L={b,e,a}
               S={c}
               Recurse()
                    oldA=A
                    oldS=S={c}
                    oldL=L={b,e,a}
                    q=c
                    S={ }, L=b,e,a,c}
                    Recurse()
                        output L={b,e,a,c}
But at the output set, node $d$ is missing. Have I done something wrong? (Thinking)
When you select q=a, not only node c is added to S, but node d should also be added to S. (Wasntme)
I tried it again...
\end{matrix}$$
Code:
    Recurse()
       oldA=A
       oldS=S={b,e}
       oldL=L={ }
       q=b
       S={e}, L{b}
       Recurse()
           oldA=A
           oldS=S={e}
           oldL=L={b}
           q=e
           S={ }, L={b,e}
           S={a}
           Recurse()
               oldA=A
               oldS=S={a}
               oldL=L={b,e}
               q=a
               S={ }, L={b,e,a}
               S={c,d}
               Recurse()
                    oldA=A
                    oldS=S={c,d}
                    oldL=L={b,e,a}
                    q=c
                    S={d}, L={b,e,a,c}
                    Recurse()
                        olA=A
                        oldS=S={d}
                        oldL=L={b,e,a,c}
                        q=d
                        S={ }, L={b,e,a,c,d}
                        Recurse()
                            output L={b,e,a,c,d}
                        S=oldS={d}
                        L=oldL={b,e,a,c}
                        A=oldA
                        q=d
                        Recurse()
Do we get the same result? Or have I set the wrong values at [m]S[/m], [m]L[/m], [m]A[/m] ? (Thinking)
First node d was selected from S={d}.
After that, all selections from S={d} were complete.
Node d should not be selected a second time from the same S={d}. (Wasntme)
So which should be the values of [m] S, L , A [/m] after the output [m]L={b,e,a,c,d}[/m]? :confused:
After that we first go back to S={d} and L={b,e,a,c}.
And since we've gone through all choices in S, we backtrack to S={c,d} and L={b,e,a}. (Thinking)
We've already had choice c, so the next choice from S is node d.
So we recurse and get to S={c} and L={b,e,a,d}.
And then we get to S={} and L={b,e,a,d,c}, which is the next solution. (Mmm)
I executed the algorithm...The set of starting nodes is: $S=\{b,e\}$.
\end{matrix}$$
Code:
    Recurse()
       oldA=A
       oldS=S={b,e}
       oldL=L={ }
       q=b
       S={e}, L{b}
       Recurse()
           oldA=A
           oldS=S={e}
           oldL=L={b}
           q=e
           S={ }, L={b,e}
           S={a}
           Recurse()
               oldA=A
               oldS=S={a}
               oldL=L={b,e}
               q=a
               S={ }, L={b,e,a}
               S={c,d}
               Recurse()
                    oldA=A
                    oldS=S={c,d}
                    oldL=L={b,e,a}
                    q=c
                    S={d}, L={b,e,a,c}
                    Recurse()
                        olA=A
                        oldS=S={d}
                        oldL=L={b,e,a,c}
                        q=d
                        Recurse()
                        S=oldS={d}
                        L=oldL={b,e,a,c}
                        A=oldA
                    S=oldS={c,d}
                    L=oldL={b,e,a}
                    A=oldA
                    q=d
                    S={c}, L={b,e,a,d}
                    Recurse()
                        oldA=A
                        oldS=S={c}
                        oldL=L={b,e,a,d}
                        q=c
                        S={ }, L={b,e,a,d,c}
                        Recurse()
                             output L={b,e,a,d,c}
                        S=oldS={c}
                        L=oldL={b,e,a,d}
                        A=oldA
                    S=oldS={c,d}
                    L=oldL={b,e,a}
                    A=oldA
               S=oldS={a}
               L=oldL={b,e}
               A=oldA
           S=oldS={e}
           L=oldL={b}
           A=oldA
       S=oldS={b,e}
       L=oldL={ }
       A=oldA
       q=e
       S={b,a}, L={e}
       Recurse()
            oldA=A
            oldS=S={b,a}
            oldL=L={e}
            q=b
            S={a}, L={e,b}
            Recurse()
               oldA=A
               oldS=S={a}
               oldL=L={e,b}
               q=a
               S={ }, L={e,b,a}
               S={c,d}
               Recurse()
                    oldA=A
                    oldS=S={c,d}
                    oldL=L={e,b,a}
                    q=c
                    S={d}, L={e,b,a,c}
                    Recurse()
                        olA=A
                        oldS=S={d}
                        oldL=L={e,b,a,c}
                        q=d
                        S={ }, L={e,b,a,c,d}
                        Recurse()
                            output L={e,b,a,c,d}
                        S=oldS={d}
                        L=oldL={e,b,a,c}
                        A=oldA
                    S=oldS={c,d}
                    L=oldL={e,b,a}
                    A=oldA
                    q=d
                    S={c}, L={e,b,a,d}
                    Recurse()
                        oldA=A
                        oldS=S={c}
                        oldL=L={e,b,a,d}
                        q=c
                        S={ }, L={e,b,a,d,c}
                        Recurse()
                             output L={e,b,a,d,c}
                        S=oldS={c}
                        L=oldL={e,b,a,d}
                        A=oldA
                    S=oldS={c,d}
                    L=oldL={e,b,a}
                    A=oldA
               S=oldS={a}
               L=oldL={e,b}
               A=oldA
           S=oldS={b,a}
           L=oldL={e}
           A=oldA
           q=a
           S={b}, L={e,a}
           S={b,c}
           Recurse()
               oldA=A
               oldS=S={b,c}
               oldL=L={e,a}
               q=b
               S={c}, L={e,a,b}
               S={c,d}
               Recurse()
                      oldA=A
                      oldS=S={c,d}
                      oldL=L={e,a,b}
                      q=c
                      S={d}, L={e,a,b,c}
                      Recursive()
                            oldA=A
                            oldS=S={d}
                            oldL=L={e,a,b,c}
                            q=d
                            S={ }, L={e,a,b,c,d}
                                Recurse()
                                     output L={e,a,b,c,d}
                                S=oldS={d}
                                L=oldL={e,a,b,c}
                                A=oldA
                      S=oldS={c,d}
                      L=oldL={e,a,b}
                      A=oldA
                      q=d
                      S={c}, L={e,a,b,d}
                      Recursive()
                            oldA=A
                            oldS=S={c}
                            oldL=L={e,a,b,d}
                            q=c
                            S={ }, L={e,a,b,d,c}
                            Recurse()
                                  output L={e,a,b,d,c}
                            S=oldS={c}
                            L=oldL={e,a,b,d}
                            A=oldA
I found all the topological sortings also by hand and I found only 3. Is it right that we have found so many topological sortings so far with the algorithm? (Thinking)
I think the possible topological sortings are:
  1. beacd
  2. beadc
  3. ebacd
  4. ebadc
  5. eabcd
  6. eabdc
  7. eacbd
(Thinking)
  1. beacd
  2. beadc
  3. ebacd
  4. ebadc
  5. eabcd
  6. eabdc
  7. eacbd
(Thinking)
In order to find the possible topological sortings, don't we apply Depth-first search and write the nodes in decreasing order as for the finishing times? (Thinking)
Yes. (Nod)
Huh? :confused:
We process the nodes in alphabetical order, which is the first solution as far as that is possible.
Then we recurse to find the other solutions. (Wasntme)
I like Serena said:
Yes. (Nod)
Huh? :confused:
I found this: http://www.cse.ust.hk/faculty/golin/COMP271Sp03/Notes/MyL08.pdf and according to the page 13, the idea of Topological Sorting is the following:
Run the DFS on the DAG and output the vertices in reverse order of finishing time.
When we do it like that, don't we get only three possible topologicsl sortings? :confused:
I got the following: [m]{b,e,a,d,c}, {b,e,a,c,d}, {e,a,c,b,d} [/m]..
But... isn't for instance [m]{e,b,a,c,d}[/m] a valid topological sorting? (Thinking)
After one node can't we only have an adjacent node of this node? Or am I wrong?
I thought that after [m] e [/m], the only node that can appear is the node [m] a [/m]... (Thinking)
(Wait) That what I said doesn't hold.. If we find at a topological sorting a node after an other, the latter doesn't have to be adjacent to the first one..
But we should have to add an other condition so that we get only the right three possible topological sorting, but I can't think of one..
Do you maybe have an idea? (Thinking)
Wikipedia is currently not responding, but from mathworld.wolfram I have:
A topological sort is a permutation p of the vertices of a graph such that an edge {i,j} implies that i appears before j in p (Skiena 1990, p. 208).
The sorting I gave fulfills the conditions of that definition.
So I really think there are 7 topological sortings. (Thinking)
EDIT: Wait! (Wait) Wikipedia is responding now. It says:
In computer science, a topological sort (sometimes abbreviated topsort or toposort) or topological ordering of a directed graph is a linear ordering of its vertices such that for every directed edge uv from vertex u to vertex v, u comes before v in the ordering.
Anyway, it's the same thing. (Worried)
  • #31
In my book, there is the following algorithm:
Code:
TOPOLOGICAL-SORT(G)
    1.  call DFS(G) to compute finishing times v.f for each vertex v
    2.  as each vertex is finished, insert it onto the front of a linked list
    3.  return the linked list of vertices
  • #32
Wouldn't that algorithm return just 1 solution? (Wondering)
  • #33
Yes, it would.. But DFS doesn't always return the same result. If we apply for example twice the DFS at a graph and at one step, there are two different nodes to visit, we can once visit firstly the first node and the second time when we apply the algorithm we would visit firstly the second node and so the results would be different, since the finishing times would be different.For example if we have this graph:View attachment 4263
applying DFS we could get these discovery and finishing times:View attachment 4264these ones:View attachment 4265
or these ones:
View attachment 4266So at the first case, the result of the topological sorting would be: {b, e, a, d, c}, at the second case the result would be: { b, e, a, c, d} and at the third case: {e, a, c, b, d}.How could an algorithm return all these possible results of topological sorting?
  • #34
I don't understand. (Sweating)
What do your arrows and your numbers mean? (Wondering)
  • #35
The numbers respresent the discovery and finishing times. The arrows show from which node we came to the current one.I applied only DFS, starting with the nodes that have no incoming edges. (Tmi)
Now I got the following topological sortings:
[m] {e, b, a, d, c}, {b, a, a, d, c}, {b, e, a, c, d}, {e, b, a, c, d}, {e, a, c, b, d}, {e, a, b, d, c}[/m]
But I haven't found the topological sorting [m] {e, a, b, c, d}[/m].. How do we get it? (Thinking)
To find this, we should start from the node [m]d [/m], or not?
  • #36
What are "discovery and finishing times"? (Wondering)
It's a variant of [m]{e, a, b, d, c}[/m] where only the last 2 nodes are swapped around, which has no impact on the topological ordering. How is it that you did not find it? (Wondering)
  • #37
The DFS procedure takes as input a graph $G$, and outputs its predecessor subgraph in the form of a depth-first forest. In addition, it assigns two timestamps to each vertex: discovery and finishing time.
The algorithm initializes each vertex to “white” to indicate that they are not discovered yet.
It also sets each vertex’s parent to null. The procedure begins by selecting one vertex u from the graph, setting its color to “grey” to indicate that the vertex is now discovered(but not finished) and assigning to it discovery time 0.
For each vertex v that belongs to the set Adj, and is still marked as “white”, DFS-Visit is called recursively, assigning to each vertex the appropriate discovery time d[v] (the time variable is incremented at each step).
If no white descendant of v exists, then v becomes black and is assigned the appropriate finishing time, and the algorithm returns to the exploration of v’s ancestor (v).
If all of u’s descendants are black, u becomes black and if there are no other white
vertices in the graph, the algorithm reaches a finishing state, otherwise a new “source” vertex is
selected, from the remaining white vertices, and the procedure continues as before.
I think that we do not get it, applying all possible DFS. Or have I done maybe something wrong? :confused:
  • #38
  • #39
So even if we want to find a topological sort, can we visit at each step any node, even if it has incoming edges?
Because in this case, we also get the output {e, a, b, d, c}... :confused:
  • #40
Ah! That explains it. (Mmm)
Your DFS algorithm appears to finish each subtree before moving on to the next subtree.
However, that is not a requirement for a topological ordering.
So you're missing out on some topological orderings. (Thinking)
Yes, we can visit any node in each step.
And yes, that node can have incoming edges, as long as all its predecessors are already in the current topological ordering. (Wasntme)
  • #41
Code:
    L: output set
    A: adjacency matrix
    Recurse()
    Recurse(){
         if S empty
            output L
         oldA = A
         oldS = S
         oldL = L
             // Execute choice
             Alg(q)
             // Recurse
             Recurse()
             // Undo choice
             S = oldS
             L = oldL
             A = oldA
    Alg(q){
         for i=1 to |V| {
              if (A(q,i)==1){
                   A(q,i)=0
              for j=1 to |V| {
                   if (A(j,i)==0){
                       k=k+1
              if (k==|V|){
                  add i into S
How can we find the complexity of the algorithm?
I am a little confused because we have a function that calls itself recursively in a for-loop. :confused:
  • #42
If we want to have all the topological sortings in an array do we have to do the following? (Thinking)
I tried to implement the algorithm in C.
Code:
    S: array of starting nodes
    L: output array
    A: adjacency matrix
    Recurse()
    p=0;
    Recurse(){
	    k=0;
        for (i=0; i<length(S); i++){
	        if(S[i]==NULL){
		        k++;
	    if(k==length(S)){
        	for (j=0; j<V; j++){ // V=number of vertices
             	T[p,j]=L[j];
        	p++;
         //output L
         for(i=0; i<V; i++){
	         for(j=0; j<V; j++){
         		oldA[i,j] = A[i,j];
         for(i=0; i<length(S); i++){
         	oldS[i] = S[i];
     	 for(i=0; i<length(L); i++){
         	oldL[i] = L[i];
	         L[i]=S[i];
	         S[i]=NULL;
             // Execute choice
             Alg(q)
             // Recurse
             Recurse()
             // Undo choice
         		S[i] = oldS[i];
             for(i=0; i<negth(L); i++){
         		L[i] = oldL[i];
             for(i=0; i<V; i++){
	         	for(j=0; j<V; j++){
         			A[i,j] = oldA[i,j];
    Alg(q){
         for (i=0; i<V; i++){
              if (A(q,i)==1){
                   A(q,i)=0
              	   for (j=0; j<V; j++) {
                   		if (A(j,i)==0){
                       		k=k+1
                   if (k==V){
                       S[length(S)++]=i
  • #43
Suppose [m]Recurse()[/m] is called with an $S$ of size $n$.
Then the for-loop is executed $n$ times and the Recurse() inside the for-loop is called with an $S$ of size $n-1$.
So:
$$T(n) = n \times (T(\colorbox{lightgray}{Alg(q)}) + T(n-1) + constant) + constant$$
(Thinking)
  • #44
So:
(Thinking)
How can we find the complexity?
I calculated it in Wolfram and I got the following:
https://www.wolframalpha.com/input/?i=T%28n%29%3Dn%2AT%28n-1%29%2Bn%5E3%2C+T%280%29%3D1
So isn't it possible to solve the recurrence relation?
  • #45
Couldn't you use the "natural" divide and conquer algorithm derived from the properties of topological orderings (i.e. pick any vertex, find all vertices less than, all vertices greater than, distribute incomparable vertices and recurse on the left and right vertex sets) or is the backtracking algorithm more efficient?​
  • #46
I haven't heard of this algorithm. Could you explain to me further how it works? Can we find in that way all the possible topolgical sortings? What would be its time complexity?
  • #47
In general, what is the best way to find all the possible topological sortings in at most quadratic time? (Thinking)
