Alternative form of Minkowski metric?
stanleyfapps
I've tried to find this addressed in other threads without success, so I apologize if it has already been addressed.
In Coleman and De Luccia (Gravitational effects on and of vacuum decay), they suggest that by analytic continuation (\[\xi = i\tau \]):
\[ds^2 = -d\xi ^2 - \rho (\xi )^2(d\Omega_S )^2\]<br />
becomes
\[ds^2 = d\tau ^2 - \rho (i\tau )^2(d\Omega_T )^2\]
and if \[\rho (\xi ) = \xi \], this is "ordinary Minkowski space." However, it doesn't look like Minkowski space to me. Does anyone know what transformation makes this look like ordinary Minkowski space?
How does this transform to look like Minkowski space?
\[ds^2 = d\tau ^2 + \tau^2(d\Omega_T )^2\]
Is \Omega_T a solid angle in two dimensions (theta and phi), or is it a solid angle in three dimensions (theta, phi, and some other angle like eta)? In other words, do you even have 4 dimensions total, or just 3?
What are the definitions of \Omega_S and \Omega_T, and how do they differ from one another?
\[d\Omega_T \] is the element of length on a unit (3-dimensional) hyperboloid with spacelike normal vector in Minkowski space.
\[d\Omega_S\] is the element of length for a unit hyperboloid with timelike normal vector in Minkowski space.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
