How Does Reciprocating Motion Affect Alternator Efficiency?
Reciprocating motion in wave energy converters can impact alternator efficiency due to the continuous stop-start nature of bi-directional rotating turbines. While there is no inherent energy loss in such systems, factors like slippage and friction may reduce overall efficiency. The cyclic operation results in less energy availability compared to systems with constant energy input, such as falling water. A theoretical reduction factor of about 1/√2 is suggested as a best-case scenario for efficiency loss. Understanding these dynamics is crucial for optimizing wave energy converter designs.
JJ21
Hi guys,
Currently just looking through a few concepts for wave energy converters and I noticed that a few designs use bi-directional rotating turbines (or linear action) meaning the alternator has to continuously keep rotating in one direction, stopping, rotating in the other direction, stopping etc etc. I would have thought that this continuous stop start would severely affect the alternator's efficiency and the power generated? If anyone knows of any papers on this or it would be much appreciated.
Thanks
There are many examples of machines with reciprocating motion. There is no inherent energy loss involved (as in a pendulum) although slippage and friction could be factors which could reduce efficiency.
The cyclic nature of these systems would mean that less energy would be available than for a system where water is, for instance, falling all the time from a height. But you 'take what you can get', surely and you are probably talking about something like a 1/√2 reduction factor (best case) which isn't too bad.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
