Amplitude of field with phasor components
To find the amplitude of a time-varying field represented by phasors, the instantaneous amplitude can be calculated using the real parts of the complex components: f = √(Re(X)² + Re(Y)² + Re(Z)²). The time-averaged amplitude is given by F_avg = √(X_rms² + Y_rms² + Z_rms²), where X_rms is derived from the complex conjugate of X. The total amplitude of the field is expressed as |F| = √(F* · F) = √(X*X + Y*Y + Z*Z), representing the magnitude in a six-dimensional space. This approach effectively utilizes phasor arithmetic similar to that in electronic circuits. Understanding these calculations is essential for analyzing time-varying fields.
misho
Let's say I have a field (electric or magnetic or something) and it's time-varying so I choose to represent its components as phasors.
Say the field is:
\vec{F} = X\hat{x} + Y\hat{y} + Z\hat{z}
where, X, Y and Z are complex numbers.
Now, I want to find the amplitude of the field. If X, Y and Z were real (time constant field), I'd just go:
F = \sqrt{X^2 +Y^2 +Z^2}
but I have no idea what to do here. Also, I'm not sure if there's an easy way to do this or not. Any ideas?
It works just like phasor arithmetic for electronic circuits. The instantaneous amplitude will be
f = \sqrt{\Re (X)^2 + \Re (Y)^2 + \Re (Z)^2}
F_{avg} = \sqrt{X_{rms}^2 + Y_{rms}^2 + Z_{rms}^2} = \sqrt{\frac{X^*X + Y^*Y + Z^*Z}{2}}
where X^* is the complex conjugate of X.
Lastly, the total amplitude of F is
|\vec F| = \sqrt{\vec F^* \cdot \vec F} = \sqrt{X^*X + Y^*Y + Z^*Z}
This is the magnitude of a vector in six-dimensional space, which rotates around on a 5-sphere such that its projections along the six axes are equal to the real and imaginary components of each of X, Y, and Z.
(Alternatively, you can think of F as living in three-dimensional complex space, such that its projection on each of the three complex axes gives the three complex numbers X, Y, and Z).
Thanks a lot! Answers my question perfectly.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
