An abstract long-distance correlation experiment
242 replies · 35K views · last reply
It seems that the discussion of the basic setting has subsided, so that the setting is now stable and can be frozen.
I'd therefore like to ask zonde, ddd123, and stevendaryl, who in the other thread (#246, #251, #267) had expressed interest (in a discussion of stevendaryl's original setting), either to express further reservations to the exposition in post #2, or to agree to the freeze, so that I can go on to stage two of the specification.
Fine with me.
A. Neumaier said:
I was taking stevendaryl's picture as blueprint. It contained 3 pointer settings, so I assumed them.
Why are you using stevendaryl's picture as a starting point? The general idea you're starting to describe (i.e., modelling Alice and Bob as black box devices that accept inputs and emit outputs) isn't new. It's how Bell presented his result in essays he wrote between 1975 and 1990. It's also more or less how theorists working in the field think about Bell experiments (see, for instance, this review article, starting with the description of figure 1 on page 2). Have you checked that the problem you're starting to describe hasn't already been solved?
Which particular items in the postselection protocol give rise to the loophole you claimed exists?
I was referring to the detection loophole. You had Alice and Bob (now partially Yvonne) deciding what to record as an event based on when they observe a result and what the result is (specifically, whether and how many lights they see go on). A local hidden variable model can potentially exploit this to fake a Bell violation. This is a well known loophole in experimental Bell tests.
A. Neumaier said:
Yes, but the fewer observables the simpler the later analysis.
Not necessarily. One joint probability distribution ##P(ab \mid xy)## isn't conceptually difficult to reason about. Then the general problem is to decide if a given probability distribution is "strange" or "quantum" or "nonlocal" or whatever it is you want to study. With regard to Bell's theorem, there are some very useful general observations that can be made about local probability distributions before concentrating attention on a more restricted scenario and/or statistic.
But when you, the analyzer, try to publish the results in Phys. Rev. Lett. there is a 4 page limit to describe and justify everything - your motivation, your experimental setting, the choices of the details, the statistics, your conclusions, and all references; clearly the less statistics must be explained and displayed the better. You just need to pick the statistical observables that produce the aha effect in the most pronounced way.
In real life research papers (including PRLs) reporting a Bell experiment, the main result is normally just one statistic (the value of a Bell correlator such as CHSH) along with some measure of confidence. In theoretical research papers on Bell and similar scenarios its quite common to start by imagining one has access to the full table of joint conditional probabilities and take this as the object of study.
Because he created the picture during the discussion that gave rise to the present thread, and because his description was complete but didn't refer to Bell's theorem or to particles or to knowledge or to entanglement but just to observable stuff, postulating a particular outcome. If there are earlier such descriptions in the literature it matters for the history, but not for the present discussion.
Concerning loopholes, I don't think this is very relevant for this thread. We are not going to prove that no local realist explanation is possible. The concern of this thread is about weirdness and how it is caused by language, not about nonlocal correlations and how they cannot be caused by local hidden variables.
I don't think the results of nonlocality experiments would be less weird if it were impossible to close all loopholes. At least, 15 years ago, I already thought that Aspect's experiment (together with the fact that QM proved to be the right description of all microscopic phenomena) was proof enough for establishing nonlocal correlations. But I still found everything weird at the time.
As I allowed for supplementary material, the remaining information, while informative, doesn't affect the basic setting. It didn't mention the specific limitations of PRL.
whereas I deliberately eliminated any human imagination from my basic setting.
Well we can't rule out that one way to remove the weirdness would involve going along the lines of loopholes. But concerning postselection if, as you say, we will consider asymptotic probabilities as we have no practical constraints, I don't see much of a possibility for that loophole anymore. Maybe wle disagrees with this.
Hi There. I am in the process of building an animation to match your parameters in post #2. The steps for a given event are:
1. Generate a photon with a random polarization angle between 0 and 360
2. Split the photon with a BBO crystal and point at Bob and Alice
3. Set a random polarization angle of 0, 120 or 240 to each of Bob and Alices's detector
4. Record if a photon is detected and send a 2 x 3 matrix of numbers to Yvonne
For the detection event, at this time I am using the classical description of the photon used by Dehlinger and Mitchell in http://arxiv.org/PS_cache/quant-ph/pdf/0205/0205171v1.pdf. When a photon meets a polarizer set to an angle γ , it will always register as Vγ if λ is closer to γ than to γ + π/2, i.e.,
  • if |γ − λ| ≤ π/4 then vertical
  • if |γ − λ| > 3π/4 then vertical
  • horizontal otherwise.
At this point I am not sure what to put in the matrix? You can see an example of a run below where a 272° photon is shot, Bob sets his detector to 120° and is hit, likewise Alice sets her detector to 240° and is hit. What should their respective matrices they send to Yvonne look like?
Screenshot of an animation showing a photon at 272 degrees, with Bob's detector set to 120 degrees (hit) and Alice's detector set to 240 degrees (hit), and a table of red and blue detection counts for each setting.
Animation at: http://www.animatedphysics.com/games/photon_longdistance_nonlocality.htm
The NEXT button (not done yet) will generate a continuous stream of these events.
Thanks.
stevendaryl said:
I always go for three, because it's the easiest to see the weirdness of quantum statistics. Three was also used by Dr. Chinese in his essay here:
http://drchinese.com/David/Bell_Theorem_Easy_Math.htm
... With three choices, you can show that no hidden variable theory works, but not with just two.
Great post, I agree on your two choice assessment, but I disagree on your assessment of three choices. Here is why I feel that way. The quoted essay, is making the assumption that a split photon will measure the same on both Bob and Alice's detectors if Bob and Alice both have the same settings no matter what the original angle of the photon was. Ie. he assumes that if both Bob and Alice have an angle of 120° set on their detectors, the result of a 100° photon hit will be the same for each. This is wrong as a photon only has a certain probability of being detected if measured off of its basis vectors, hence Bob and Alice may or may not measure the photon the same.
Another way to put this, The only things certain about a vertically polarized photon is that it has a 100% chance of going through a vertical filter, and a 0% chance of getting through a horizontal filter. If Bob and Alice measure photons at 45°, each has a 50% chance of detecting them, but the ones Bob detects may or may not be the same ones that Alice detects. The essay is ignoring the fact that at smaller angles, say for example 22.5°, both Bob and Alice have a greater then 75% chance each of detecting the photons (predicted by classical models, quantum mechanics predicts a higher number). There is nothing "weird" about this that cannot be resolved if you take into account the statistical nature of photon polarization. The quoted essay does not do this.
OK. Fair enough, if this is mainly a discussion between you and stevendaryl rather than about locality.
Fair enough again, but then aren't the steps concerning postselection a bit unnecessary? Why not just assume that the devices always output clean results (one and only one of the lights goes on) at regular time intervals?
I already deleted the part of my post on PRL length limits before you replied since I decided it was an unnecessary distraction.
This is taking what I said out of context.
edguy99 said:
The only things certain about a vertical photon is that it has a 100% chance of going through a vertical filter, and a 0% chance of getting through a horizontal filter. If Bob and Alice measure photons at 45°, each has a 50% chance of detecting them, but the ones Bob detects may or may not be the same ones that Alice detects.
This is precisely the natural assumption that QM rejects. There are no "vertical photons". As long as the detector angles are the same, we get perfect correlation.
If it's not relevant then why you changed stevendaryl's version into another one that allows double detections at one side and unpaired detections?
stevendaryl said:
Each time the source sends its signals, exactly one of Alice's LEDs light up, and exactly one of Bob's LED's light up.
Detection loophole can be eliminated if we count discarded events and set a limit that say there can be no more than 10% of discarded events from total events (and if there are more we do not consider result).
And communication loophole should be eliminated too. You gave exact number for minimum distance between Alice, Bob and Norbert (1km). So let's set maximum value for ##\Delta t## to ##3 \mu s##.
What about photons that have passed through a vertical filter? These photons will pass through a second vertical filter 100% of the time and will never get through a horizontal filter. All other angles have an element of randomness.
After some thought, perhaps a clarification. I mean a vertical photon with a Jones Vector labeled vertical in the diagram below.
Diagram of photon polarization states showing Jones vectors, Bra-Ket notation and the Poincaré-style circle plots for horizontal, vertical, 45 degree up and down, spin right and spin left, with a Jones vector and Bra-Ket expression for a general state.
But if they are only counted when both measure it, they'll get the stated results. This is why I added an appropriate postselection to guarantee this with very high probability in spite of detector inefficiency.
##E=0##, ##F## will have 3 zeros and a 1 in the position corresponding to the color of the lights seen.
In a continuous run you start with all matrices initialized with zeros, and (assuming for simplicity that all events are valid and paired) after each such event add a 1 to the correct entry in both ##A## and ##B##, and a 1 to the correct entry in either ##E## or ##B##, depending on the pointer settings. You also count the number of valid pair events. After the experiment is completed you divide all matrices by this number. This is the final result. (If there are errant photons and/or detector inefficiencies you need a more sophisticated updating procedure, as you need to make sure that each matrix only counts the valid signals. In this case you need to make three counts, one for Alice alone, one for Bob alone, and one for Yvonne (who analyzes the complete results), and update the matrices only after enough time has passes so that one knows whether the signal was valid or spurious. Also, note that Yvonne's criteria for validity are more restrictive than those for Alice and Bob.
I added it because I wanted the experiment to be realistic. One cannot realize stevendaryl's results in practice without postselection for errant photons and for missed photons - which could create the items you mentioned. I wanted to both keep his results as a valid possibility and have an experimental setting that produces it.
I don't care about the loophole since if they were the cause of the nonclassical correlations, Nature would in my eyes even be weirder than quantum mechanics ever was before I found the view I presented in the other thread!
OK, I added this to the basic setting; see the updated points 1 and 6 in post #2.
A. Neumaier said:
OK, ill add this to the basic setting.
Ok, no more comments from me.
Your language is inviting misunderstanding.
If a photon goes through a polarizer producing vertically polarized light, the result is not a vertical photon but a vertically polarized photon.
Thank you for the clarification, I will amend my comments.
My point was simply that in the EPR scenario only the entanglement of the particles is part of the state before detection, not the individual spins. That's how QM describes the experimental fact that equal detector angles give perfect correlation, no matter what the shared angle is.
OK, consensus has been established about the basic setting. Thus it will be frozen, and is not open to discussion anymore.
I'll soon begin with stage two.
In the second stage of our interactive specification, I want to augment the basic model by adding some information about you, the analyzer - a quantum-mechanical system much more complex than a detector.
As we reduced the detector description to its essential degrees of freedom (a 3-valued input and two 2-valued outputs), so I'll reduce the description of you (with your help) to one essential degree of freedom - essential just for the purposes described in the updated initial post of this thread: a single [0,1]-valued variable ##W## called the degree of weirdness. It is a function ##W(A,B,D,E)## of the matrices we assumed that you'd publish about the experiment if the outcome is interesting enough. For simplicity we refer to a list ##R:=(A,B,E,F)## as a valid result if if it has the form specified in the basic setting and satisfies the trivial conditions for relative frequencies (entries are in [0,1]; sums of relative frequencies have the same value if their meaning is the same). For any valid result ##R##, ##W(R)\in[0,1]## is supposed to be a sensible approximation to the degree of weirdness that you assign to the statistical situation described by ##R##.
Since weirdness is in the eyes of the beholders, each single you is likely to have a different weirdness function. However, they should have the following in common:
  1. All situations that correspond to common experience should have ##W=0## since they are not weird at all.
  2. All situations that you personally find really weird should have ##W=1##.
  3. If you believe that quantum mechanics is intrinsically weird, you should exhibit at least one valid result ##R## (of your choice) for which ##W(R)=1##, and outline, in agreement with quantum mechanics, how Norbert can generate signals and which local detector response is required to obtain the valid result ##R##. Please justify in words and references to other discussion or the literature why you consider the result to be weird.
  4. The degree of weirdness should be quasiconvex, i.e., ##W(\lambda R+(1-\lambda)R')\le\max(W(R),W(R'))## for ##0<\lambda<1##. This is needed since if Norbert can create signals leading to the valid results ##R## and ##R'##, he can always present in another experiment signals prepared in a statistical mixture of the original signals, in this way producing a signal leading to the valid result ##\lambda R+(1-\lambda)R'##. Clearly, this should not increase the degree of weirdness.
  5. Small perturbations ##R'## of valid results ##R## with ##W(R)=0## should have ##W(R')\approx 0##, and small perturbations ##R'## of valid results ##R## with ##W(R)=1## should have ##W(R')\approx 1##. This is to account both for the well-known fact that relative frequencies are not precisely predictable, and for imperfections in the experiment itself, since a signal might be distorted on the way from Norbert to Alice or Bob, and since the devices might be so sensitive that they occasionally respond to a signal not caused by Norbert. (The postprocessing tries to reduce the likelihood of this but cannot suppress it completely.)
My personal weirdness function is very easy to state. Since I no longer find anything weird in quantum mechanics (except for the endless discussions about it), the personal degree of weirdness is given by ##W(R)=0## for all valid results ##R##.
On the other hand, I cannot guess the degree of weirdness assigned by any of you who believe that quantum mechanics is intrinsically weird.
Therefore I invite those of you who don't share my judgment about quantum weirdness to observe yourself sufficiently well to be able to come up with a deterministic approximation ##W(R)## to your subjective judgment of the degree of weirdness of any valid result ##R##, having the properties mentioned. (You may learn in this way something new about yourself, or about the experimental setting, or both.)
If you find it too difficult to define a degree of weirdness satisfying all conditions, please specify at least a weak degree of weirdness which is a lower bound to the full degree of weirdness. Then property 4 (quasiconvexity) is not needed, and property 2 is relaxed - you only need to guarantee that there is at least one ##R## where ##W(R)=1##.
If you are not sure about yourself, you could alternatively work out a choice for the degree of weirdness that, in your opinion, would encode a sensible approximation to the judgment of a hypothetical rational local realist. Note, however, that my goal in this discussion is not to prove or disprove local realism in the conventional form, but to investigate weirdness in quantum mechanics and its dependence on the language chosen.
Whatever you specify will count as a possible weirdness measure for subsequent discussion. Initially we'll discuss whether the above scheme needs amendment, as well as a few checks on whether you actually meant what you proposed, and you can change your proposal until it remains stable.
Then all surviving proposals for the degree of weirdness will be frozen and we'll go on to stage four. (Stage three starts at post #119 and ends at post #186, and discusses an important part of my reasoning about the weirdness of the present setting. Stage 4 starts at post #187, and discusses implications for relativistic causality.)
I would modify your weirdness function like this. Any outcome predicted by quantum mechanics gets W=0, and any outcome that contradicts a quantum mechanics prediction gets W=1. This reflects the idea that I have learned to strongly favor the predictions of quantum mechanics over any other expectations I might have formed by living my daily life. Also, it allows me to avoid assuming that the QM prediction must always be the same thing as the outcome of the experiment. I presume this approach is functionally equivalent to yours, in the sense that it relaxes the idea that "weirdness" means "disobeys preconception", and embraces the idea that weirdness means "doesn't conform to a well-tested theory we should have expected to work based on all our prior knowledge, including knowledge of quantum mechanics." Basically, it means that we learn what to call "weird." I think most people who argue for a different concept of weirdness in quantum mechanics use a different meaning of "weird", more along the lines of "surprising that it is true, even after you have come to expect it to be true."
If you do this your concept loses contact with those mentioned in the last sentence of your post. But this thread arose through discussions with proponents of the widespread view that quantum mechanics has to be intrinsically weird; so it is appropriate to use their notion of weirdness.
That's kind of my point-- how weird we view the situation depends more on our personal relationship with the concept of weird than on the experimental outcomes. There are experiments that surprise us, are they all weird? Most people were surprised that there was length contraction and time dilation, are they as weird as quantum mechanics? Looking back into history, most people were surprised that the laws of motion can only tell you accelerations, you need to know the current velocity to get the motion going forward, so is that as weird as quantum mechanics? I'd say that all of physics was pretty surprising at one point or another, so if we define "weird" to mean "surprising to anyone", then all of physics is equally weird, and if we define "weird" as "surprising to me", then what is weird is a function of the knowledge of that person, not anything in the physics itself.
This is what I am investigating in this second stage, trying to give it at least some precision so that one can afterwards make some objective statements about the models of the subjective degree of weirdness.
The main difference between QM and all your other examples is that, once, say, SR was established, the debate virtually stopped and all physicists agreed about length contraction from then onwards. QM is the only case in which there is no agreement: foundations is a thorny subject with a lot of, often colorful, disagreements, even some 100 years after QM started being investigated.
OK, let me suggest two candidates for degree of weirdness.
Candidate number one is the degree of entanglement. I believe there are serious papers in the literature tdefining a degree of entanglement. I think they should be transformable into your form fairly readily.Candidate number two is the degree of nonlocality. Maybe some function from Bell or CHSH can be adapted to your form.A third possible candidate which I do not advance is the degree of nonreality. First of all, every theory of nonreality gets an automatic weirdnesss rating of one, if not infinity from me. Second of all, I am not aware of a serious attempt to measure the degree of nonreality, similar to nonlocality or entanglement.
I am willing to learn more about nonreality, but so far, I think that like Oakland, “there is no there there.”
Best.
Jim Graber
There is some value in that approach to "weirdness", it is a rather different one but perhaps the most useful. It sounds like you are saying we should not regard "weird" as equal to "surprising to us", and certainly not "surprising to someone who does not know physics", but instead "still exhibiting a remarkable variation in foundational concepts among practicing physicists." That makes weirdness not a personal issue any more, but rather something that can be observed across a community of scientists, which is what I think is good about it. Still, to play devil's advocate to that version of "weirdness", I would point out that classical mechanics supports many different interpretations as well-- is it forces, is it a principle of least action, or is it just the macroscopic correspondence of quantum mechanics? Notice that if we take that last view, then even something as simple as rolling a die inherits all the same interpretations as quantum mechanics does, and always did-- it's just that few took those other possible interpretations seriously before.
PS I'm assuming that something similar to these three proposals would be the "mainstream response" of many other physicists.
jimgraber said:
Candidate number one is the degree of entanglement. I believe there are serious papers in the literature defining a degree of entanglement. I think they should be transformable into your form fairly readily.
Can you please give formulas, or at least definite references, so that it is documented what you refer to?
Note that according to my setting, the degree of weirdness must be a function of the experimental results ##R=(A,B,D,E)## only, not a function of the prepared state, which we do not know if we don't have access to what precisely Norbert prepared. My degree of weirdness is about observable things only, not about the theory behind it.
Ken G said:
I answered in the other thread to keep things tidy.
A. Neumaier said:
... In a continuous run you start with all matrices initialized with zeros, and (assuming for simplicity that all events are valid and paired) after each such event add a 1 to the correct entry in both ##A## and ##B##, and a 1 to the correct entry in either ##E## or ##F##, depending on the pointer settings...
Thank you for your assistance, I believe the animation matches the specifications. It stops between each photon to show what each of the people is recording and it allows you to shoot additional photons to verify proper operation and build up a data set (continuous operation will come with the NEXT button, not yet done). Looking forward to use of the data to study "wierdness". At this point, I am still using the classical description of the photon used by Dehlinger and Mitchell in http://arxiv.org/PS_cache/quant-ph/pdf/0205/0205171v1.pdf. When a photon meets a polarizer set to an angle γ, it will always register as Vγ if λ is closer to γ than to γ + π/2, i.e.,
A sample run is shown below after 4 photon shots.
Screenshot of a long-distance nonlocality simulation showing Shot 4 at Angle 92 degrees, Bob at 120 degrees hit, Alice at 0 degrees, with tables of Alice and Bob blue and red results and Yvonne's E and F matrices.
