The Mystery of Carol and Her Father's Ages
  • Thread starter Thread starter bindwood
    Mystery
Carol's age can be determined by reversing the digits of her father's age, with both ages having digits that sum to 10. The positive difference between their ages is stated to be 36. The user identifies four potential age pairs: (19,91), (28,82), (37,73), and (46,64), noting the differences between them. The user is confused about the correct answer, which is indicated as being less than 36, suggesting a misunderstanding of the problem. The discussion emphasizes the importance of checking previous posts to avoid redundancy in questions.
bindwood
carol's age in years, can be expressed by reversing the digits in her father's age, in years. the sum of the digits in each age is 10.
the positive difference between carol's age in years, and her fater's age in years___36
a.>
b.<
c.=
d.uncertain
In my opinion, there are four pairs: (19,91),(28,82),(37,73),(46,64). the differences are 72,54,36,18 respectively. so I choose d. But the answer is b, I was confused. Am I wrong or the answer is incorrect? Can you throw some ideas? Any help would be much appreciated.
Please don't "double post" homework questions. The same question has been answered in your earlier thread, albeit four minutes later than the current one.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
11K
14K
