An experiement -- Would it work?
  • Thread starter Thread starter Shain
    Work
The discussion revolves around the relationship between a perfect sphere, its circumference, and the mathematical constant pi. It asserts that if a sphere's diameter is set to 1, then its circumference naturally equals pi, emphasizing that the choice of unit systems is arbitrary. Participants question the concept of growth in this context, clarifying that a sphere defined in this way does not grow. The conversation also touches on common confusions between radius and diameter. Ultimately, the discussion highlights the simplicity of mathematical definitions in geometry.
Shain
If you had a perfect sphere, and pi was it's circumference, what would happen? Would it be complete? Would it grow forever? How fast would it grow?
Shain said:
what would happen?
It's diameter would be 1 in the same units you used for circumference. Otherwise nothing at all.
All spheres have Pi as the circumference if you arbitrarliy declare a unit system where r=1. That's what Pi means. The units we use (meters, feet) are abitrary and unnecessary and mathematically it is simpler to just use a unit of D=1, so C=Pi.
http://en.wikipedia.org/wiki/Unit_circle
Grow? Why would it grow? And how is this an experiment?
russ_watters said:
r=1, so C=Pi.
I'm glad I'm not the only one who keeps confusing radius and diameter. :wink:
Oops. Corrected.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
