Analysis of Truss Structure: Horizontal Component at Hinge?
  • Thread starter Thread starter cuddlesome
    Analysis Structure
6 replies · 3K views
cuddlesome
If the loads are all vertical in a truss, will there be horizontal component on the hinge of the given truss?
Does the presence of the horizontal component depends on the design of the truss?
Usually there is a later component in a truss, or a diagonal element. However, I would expect some lateral element because structures are 3-D.
diagram:http://instruct1.cit.cornell.edu/Courses/ansys/truss/images/truss.jpg
Will there be a horizontal force component at A?
Yes - I would have thought that was pretty obvious looking at the diagram.
Consider taking moments about point C.
Just to echo what mgb_phys mentioned, you should be able to visualize the forces at A in your mind. If you were to pull down at that point, can you not convince yourself that the member AB will not pull diagonally on point A?
Thanks - I was worried that I sounded a bit condescending - then I noticed the cornel.edu address and figured this wasn't a grade4 student!
