MHB Solve for a,b,c,d Solve \frac{f(-1)+f(1)}{2}=f(0) for a, b, c, d
  • Thread starter Thread starter Bushy
    Analysis
The discussion revolves around solving the equation \(\frac{f(-p)+f(p)}{2}=f(0)\) for a cubic function \(f(x) = ax^3 + bx^2 + cx + d\) given three collinear points. The initial attempt incorrectly assumed \(f(-p) + f(p) = 0\). By letting \(p = 1\) and analyzing the function, it is shown that \(b\) must equal zero, simplifying the function to \(f(x) = ax^3 + cx + d\). Consequently, it is established that \(\frac{f(-x)+f(x)}{2}=d=f(0)\), confirming the relationship holds true for the cubic function. The discussion effectively demonstrates the conditions for collinearity and the implications for the coefficients of the cubic function.
Bushy
For a cubic function $$y=f(x)$$ three points A, B and C lie on a straight line with respective coordinates (-p,f(p)),(0,f(0)) and (p,f(p)) where p is a non zero constant.
a. Show that $$\frac{f(-p)+f(p)}{2} =f(0)$$
I tried
$$\frac{f(-p)+f(p)}{2} =\frac{0}{2} = 0 = f(0)$$
That doesn't seem right
b. Let p =1 and [math]f(x) = ax^3+bx^2+cx+d [/math]
i. Show that b=0
ii. hence [math]\frac{f(-x)+f(x)}{2}=f(0)[/math]
Mathematics news on Phys.org
I think you meant to give the coordinates of $A,\,B,\,C$ as $(-p,f(-p)),\,(0,f(0)),\,(p,f(p))$. If the 3 points are collinear, then we can write:
$$f(\pm p)=f(0)\pm k$$
Let's let:
$$f(x)=ax^3+bx^2+cx+d$$
So, we find that:
$$f(0)=d$$
And then we must have:
$$ap^3+bp^2+cp=k$$
$$-ap^3+bp^2-cp=-k$$
Adding these two equations, we find:
$$b=0$$
And so:
$$f(x)=ax^3+cx+d$$
Then we find:
$$\frac{f(-x)+f(x)}{2}=d=f(0)$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
