Analysis questions involving inequalities
elimenohpee
Prove that -1< x < 0 implies |x^2 - 2x +1| < 1.25|x-1|
Attempt at 1st question:
|(x-1)(x^2 + x -1)| < 1.25|x-1|
-1.25 < (x^2 + x -1) < 1.25
-0.25 < x^2 + x < 2.25
-0.5 < (x + 0.5)^2 < 2.25 **
this leads to
0 < (x + 0.5)^2 < 2.25
0 < x + 0.5 < 1.5 **
0 < x < 1
0 > x > -1
I don't have the answers to this in my book, but does this rough work for the proof look ok?
*edit: I just realized that this is completely wrong, that I didn't add correctly on the steps marked by **
Prove that -3 <= x <= 2 implies |x^2 + x - 6| <= 6|x-2|
Attempt at 2nd question:
|(x+3)(x-2)| <= 6|x-2|
|x+3| <= 6
-6 <= x + 3 <= 6
-9 <= x <= 3
how does this imply -3 <= x <= 2?? Not sure how to do this one.
Your first proof contains several algebraic mistakes, including in the first step. (x-1)(x^2 + x -1) is not the correct factorization of x^2-2x+1. The correct factorization is (x-1)^2.
Next, your have attempted to show that |x^2 - 2x +1| < 1.25|x-1| implies -1< x < 0. The problem you stated is to show the converse, that -1< x < 0 implies |x^2 - 2x +1| < 1.25|x-1|. In other words, you should try to run all your steps backwards.
This is also an issue for your second problem.
For example, a satisfactory proof for you second problem is as follows:
-3 <= x <= 2
-9 <= x <= 3
-6 <= x + 3 <= 6
|x+3| <= 6
|x-2||x+3| <= 6 |x-2|
|(x-2)(x+3)| <= 6 |x-2|
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
