What is the angle between two skew lines?
  • Thread starter Thread starter Kernul
    Angle Lines
The angle between two skew lines can be determined using the dot product of their direction vectors. For the lines defined by the equations r: x - 2y - 3 = 0, 3y + z = 0 and s: x = 1 + 4t, y = 2 - 3t, z = 3, the direction vectors are found to be v_r = (-2, -1, 3) and v_s = (4, -3, 0). The angle θ between the two lines is calculated using the formula cos(θ) = (v_r · v_s) / (||v_r|| ||v_s||). This approach eliminates the need to find a parallel line or construct new planes.
  • Understanding of vector operations, specifically the dot product.
  • Familiarity with the concept of skew lines in three-dimensional space.
  • Knowledge of parametric and Cartesian equations of lines.
  • Basic proficiency in calculating magnitudes of vectors.
  • Study the properties of skew lines in three-dimensional geometry.
  • Learn how to compute the dot product of vectors in detail.
  • Explore the derivation of the angle between two vectors using trigonometric identities.
  • Practice solving problems involving the angle between skew lines using different examples.
Students studying geometry, particularly those focusing on three-dimensional space, as well as educators teaching vector mathematics and its applications in physics and engineering.
Kernul
The problem asks me to evaluate the angle between these two lines:
##r : \begin{cases}
x - 2y - 3 = 0 \\
3y + z = 0
\end{cases} s : \begin{cases}
x = 1 + 4t \\
y = 2 - 3t \\
z = 3
\end{cases}##
both oriented to the decreasing ##y##.
Having found ##\vec v_r = (-2, -1, 3)##, ##\vec v_s = (4, -3, 0)##, ##P_r (1, -1, 3)##, and ##P_s (1, 2, 3)##
I already know that the lines are askew. I then found out that in order to find the angle between the two lines, I have to first find a plane containing one of the two lines(for example ##r##) that is at the same time parallel to the other one(in this example ##s##). In a few words I have to find a line parallel to ##s## that meets the line ##r## in a point that belongs to ##r##.
The thing is that I don't know how to find that parallel line to ##s## that at the same time passes into a point ##P_r## belonging to the line ##r##.
Should I take one of the Cartesian equations of ##r## and see the projection of ##s## on it so to have the parallel line? And then see the interjection between this parallel line and ##r##? Or I should proceed in another way?
By the way, this is the Cartesian form of the ##s## line I found:
##s : \begin{cases}
\frac{3}{4}x + y - \frac{11}{4} = 0 \\
z - 3 = 0
\end{cases}##
Do you know the dot product = scalar product? You don't have to construct new planes and whatever, once you have vr and vs the angle can be found in a single line on paper.
Ohw... I was so concentrated on the parallel line I didn't thought of that...
Thank you and sorry.
