Finding Radius of Curvature of a Sphere Using Angle Excess
pervect
Staff Emeritus
Insights Author
On the surface of a sphere, we can find the radius of cuvature of the sphere by:
angle excess / area = 1/ r_s^2
http://en.wikipedia.org/w/index.php?title=Angle_excess&oldid=543583039
If we use triangles, for instance, the angle excess is the sum of the angles of the triangle minus 180 degrees.
Can we use this basic idea to define the sectional curvature of a plane in terms that are relatively layman-friendly, and leverage this up to a fuller explanation of the Riemann curvature tensor?
T seems to me it's that "angle excess" is the same basic idea as talking about the parallel transport of a vector around a closed path, but expressed in simpler language.
That seems like a pedagogically good approach, but I don't know of a treatment which does it that way.
I've always been interested in the relationship of the angular defect (or angular deficit) to the fraction enclosed of a sphere-like surface, noting that by Descartes Theorem the total defect always adds up to 4pi on something similar to an ordinary sphere. For an unevenly curved surface, this remains exact, while the calculation of the effective radius of the spherical surface from the angular defect is just an approximation.
It seemed to me that the angular defect was like a conserved quantity, and therefore that it might be like the distribution of mass in the universe. However, in the 3D case, allocating the solid angle defect in this way gives additional extrinsic curvature proportional to sqrt(m)/r, not to m/r^2 as in Newtonian gravity.
Somewhat surprisingly, if you assume that the solid angle defect for the whole universe corresponds approximately to the estimated mass of the universe, of the order of 10^54 kg, then you find that the constant of proportionality for the extrinsic curvature in this model happens to be equal to the MOND acceleration parameter, and the corresponding acceleration matches the MOND law.
(Note however that this model relates to spatial curvature, not space-time curvature, and the acceleration would therefore only affect slow-moving objects if some additional assumptions were made, for example that the usual relationship of space to time curvature applies locally as in Einstein's field equations).
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
