Angled falling Meter Stick on a frictionless surface
14 replies · 3K views
stormfalconx
A meter stick is held 60 degrees to the horizontal on a flat frictionless surface. If it is let go what is the distance the back the stick will reach with respect to the length of the meter stick (l).
I = 1/3 mL^2
Don't know what to use. This seems more conceptual.
I assumed that the bottom of where the meter stick touches the ground is 0. If the stick is held at an angle and there is no net torque in the x-direction, then the center of mass should fall straight down right? I don't know where to go from there. How would I find out how far back the bottom of the meter stick has moved?
haruspex said:
Consider horizontal forces.
Do you mean the torque that is opposite the direction of falling? How does torque relate to distance though? I thought it was only equal to I*α or rFsinθ?
No, not torque. Just the horizontal forces and any consequential acceleration.
How can there be a horizontal force when an object is dropped? Am I missing a component of Fg somewhere?
stormfalconx said:
... then the center of mass should fall straight down right? I don't know where to go from there. How would I find out how far back the bottom of the meter stick has moved?
If the center of mass falls straight down, can the low end of the stick remain in its starting position? Draw a "before" and "after" picture.
Thanks for stepping in. I had fixated on the OP's reference to torque and missed that the OP had already figured out that the mass centre will descend vertically.
I think the low end of the stick will move back because the surface is frictionless. I'm attaching a drawing I made. I made the red dot the center.
I attached an image on post 9. I know the center of mass will stay vertically the same. However I can't wrap my head around how far the stick will go based on just this information.
It will help to put both positions in the one diagram, and mark the start and finish positions of the centre of the stick. Show all known distances and angles, and the distance to be found as x.
What horizontal forces did you have in mind on a frictionless table top?
Thanks I think figured it out. When I drew it out I solved for horizontal distance between the CM and point of contact with the floor. That was 0.25m and so if the CM falls straight down, it will cover 0.25m of its 0.5m for the initial horizontal distance, leaving another 0.25 meters extending over the initial point of contact.
Right!
