Angular Acceleration of a Merry Go Round: Solving a Physics Problem
The discussion focuses on calculating the angular acceleration of a merry-go-round that accelerates from rest to 10 revolutions per minute over 20 seconds. The initial attempt at solving the problem used an incorrect formula, leading to confusion about the correct approach. Participants clarify that the equations for rotational kinematics are similar to linear kinematics, emphasizing the need for proper application of these formulas. There is also a note on the importance of using accurate values for pi in calculations. The conversation highlights the challenges of understanding angular motion concepts in physics.
ixerr
A merry go round with a radius of 3 meters is at rest. The operator starts the merry go round up and it accelerates at a constant rate for 20 seconds. At the end of that time, the merry go round is moving at 10 revolutions per minute.
1) What was the angular acceleration of the merry go round?
2) What is the speed of one of the horses at the edge of the merry go round when the merry go round reaches its maximum rotation rate?
let a=angular acceleration
let w=angular velocity
let r= radius
a=rw^2
So, I solved #1 out, but I'm not sure it's right at all. Here is my work:
a=rw^2
=(3)((10*2*(22/7))/60)^2 = 3.31 rad/s^2
And I don't know how to do part 2. Please help.
You found the centripetal acceleration of the edge of the merry go round. (BTW: 22/7 is a poor approximation for pi. 3.1416 is better. 355/113 is even better.)
The problem asks you to find angular acceleration.
I know, I used pi in my actual calculation. But thanks!
And how the heck do I find angular acceleration then?! Ahh this is all too confusing :-(
The equations for rotational kinematics are much like those for one dimensional linear kinematics.
If α is constant (uniform), then:
\theta=\theta_0+\omega_0 t+(1/2)\alpha t^2
\omega=\omega_0+\alpha t
\omega^2={\omega_0}^2+2\alpha\theta
\displaystyle \omega_\text{Average}=\frac{\omega+\omega_0}{2}​
