Angular acceleration, velocity, momentum of a door?
The problem involves a door modeled as a uniform rod, focusing on its rotational motion around a vertical axis. The scenario describes an external force applied by a person to slam the door shut, with various aspects of angular acceleration, velocity, momentum, and energy being explored. Participants are tasked with analyzing the effects of different points of force application and the role of hinges in the system.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the calculation of angular acceleration and the moment of inertia, with some questioning the application of torque and the axis of rotation. There are attempts to derive equations for tangential forces and the implications of pushing at different points on the door. Several participants express uncertainty about their calculations and seek verification of their results.
The discussion is active, with multiple participants providing their calculations and questioning each other's reasoning. Some participants have offered guidance on the correct formulas to use, while others have pointed out potential errors in previous calculations. There is a mix of agreement on certain answers, but also significant debate over the correct approach and assumptions.
Participants note potential typos in the problem statement regarding the distance from the hinges and the time duration of the force application. There is also mention of the need to clarify the axis of rotation and the moment of inertia used in calculations.
  • #61
Haveagoodday said:
you have to use this equation t= θf-θi/wf-wi
you
haruspex said:
wf-wi? Did you mean that?
yes
  • #62
haruspex said:
What is the are you putting for alpha here? What units do you have for omega?
That one was closest to theta. 90 degrees.
That is the formula for rotational motion...if alpha is a constant
  • #63
Haveagoodday said:
you
yes
I've never seen that equation, and if you were to apply it you would get infinity. w does not change after the force on the door ceases.
  • #64
You did not answer either question. What number are you plugging in for alpha, and what units is your number for omega expressed in?
  • #65
Alpha is 10 rad/s...agh...I see now! Let me redo here...
  • #66
but i
dont forget that you have to use radians instead of degrees. But still it is apparently wrong to use that equation.
  • #67
Haveagoodday said:
but i
Yes?
  • #68
well it is kind of like this equation v= dx/dt, and if you rearrange it you get t=dx/dv, and same goes for rotational motion equation w=dθ/dt, at least i think so.
  • #69
I got 0.795 s
  • #70
Haveagoodday said:
well it is kind of like this equation v= dx/dt, and if you rearrange it you get t=dx/dv.
No, you get dt=dx/v. It is certainly not the case that t=dx/dv.
  • #71
coffeemanja said:
I got 0.795 s
Good, if a little inaccurate. (But why does everyone insist on decimals? What's wrong with ##\pi/4##?
  • #72
Wait... It's pi/2. I do not know, may be because we are used to use SI units..
  • #73
did you use this equation Θf=Θi+ωi*t+0.5αt^2 ?
  • #74
Yes!
  • #75
coffeemanja said:
Yes!
what are the values you put in?
  • #76
Have somebody come to a solution for e)?
  • #77
I assume you are just looking for a yes/no answer. There's a risk your question might be interpreted as a request for a solution to be posted.
  • #78
I think somebody posted an answer for part (e).
I don't know if that counts as a solution.
  • #79
Here's a starting point:
F- Fh = M* a ("h" being in a subscript of F, and "a" being "a" of centre of mass)
I could post whole my work, but I believe It's better for you that you figure it out yourself. But this starting point should be more than enough.
Let me know the result you get in e) and thereby f)
  • #80
e) Fh=F(1-3d/(2L))
f) 2L/3
  • #81
How did you get C) 0.795 s or pi/4
  • #82
  • #83
As I said, 0.795 is rather inaccurate.
  • #84
It is, but where we study they insist on decimal numbers. It is inaccurate, but the main reason why they do it is so we can use our knowledge about significant digits. You'd be surprised over how many people make silly mistakes on significant digits.
  • #85
No, it's more inaccurate than it should be for a three digit decimal. Calculate pi/4.
  • #86
Oh yeah... 0,785s...Didn't notice that they had nine instead...Sorry, my bad
  • #87
Read the book from page 308 to 314, you will understand the physics not just for one question but for all related questions.
  • #88
The thread is two years old. I doubt StavangerFinest is still interested.
  • #89
Heia Anders
  • · Replies 17 ·
17K
