Angular Kinematics & Moment of Inertia: IforPointM
The discussion focuses on calculating the moment of inertia for four point masses located in the xy plane, specifically when rotating about the x, y, and z axes. Participants emphasize the importance of converting mass to kilograms and coordinates to meters for accurate calculations. The formula for moment of inertia, I = Σ m_i r_i^2, is reiterated, highlighting the need to determine the distance from each mass to the respective axis of rotation. Visual aids, such as diagrams, are recommended to facilitate understanding of distances for each axis. An example calculation for mass 1 is requested to clarify the process further.
huybinhs
Four point masses are arranged on the xy plane as follows.
Mass1 = 27.0 grams at x = 2.00 cm and y = 2.00 cm.
Mass2 = 31.0 grams at x = 0.00 cm and y = 4.00 cm.
Mass3 = 49.0 grams at x = -3.00 cm and y = -3.00 cm.
Mass4 = 31.0 grams at x = -1.00 cm and y = 2.00 cm.
a) What is the rotational inertia if this collection of masses is rotating about the x axis?
b) What is the rotational inertia if this collection of masses is rotating about the y axis?
c)What is the rotational inertia if this collection of masses is rotating about the z axis?
I = mr2
I need to change to the right units:
Mass 1 = 0.027 kg at x = 0.02 m and y = 0.02 m
Mass 2 = 0.031 kg at x = 0.00 m and y = 0.04 m
Mass 3 = 0.049 kg at x = -0.03 m and y = -0.03 m
Mass 4 = 0.031 kg at x = -0.01 m and y = 0.02 m
Now I know each mass, and converted to the right units. What should I do next? Thanks!
The moment of inertia about an axis is
I = \sum_i m_i r_i^2,
where r_i is the distance from the point i to the axis of rotation. For each part you will need to compute the distances from each mass to the relevant axis of rotation and then compute that sum. It will probably help to draw a picture for yourself.
Ok, so on mass 1, we have x = 0.02 m and y = 0.02m. Therefore we the mass on those point (0.02, 0.02), so how can I find ri ?
The value of ri depends on which axis of rotation you are considering. It's best to draw a picture in the x-y plane with all of the points on it. Then you'll be able to just read off the distances from the x and y axes. For the z axis you can use the Pythagorean formula.
Could u give an example on mass 1 please!
