Angular momentum operator acting on |j,m>
3 replies · 2K views
PhyPsy
Prove that [itex]e^{-i \pi J_x} \mid j,m \rangle =e^{-i \pi j} \mid j,-m \rangle[/itex]
[itex]J_x \mid j,m \rangle =\frac{\hbar}{2} [\sqrt{(j-m)(j+m+1)} \mid j,m+1 \rangle +[/itex]
[itex]\sqrt{(j+m)(j-m+1)} \mid j,m-1 \rangle][/itex]
Expanding [itex]e^{-i \pi J_x}[/itex] to a power series and applying the equation in #2, I come up with an expression with coefficients for [itex]\mid j,m \rangle[/itex], [itex]\mid j,m+1 \rangle[/itex], [itex]\mid j,m-1 \rangle[/itex], [itex]\mid j,m+2 \rangle[/itex], [itex]\mid j,m-2 \rangle[/itex], and so on as far as the quantum number j allows. I will focus on the [itex]\mid j,m \rangle[/itex] term.
[itex]\left\{ 1+ \sum _{n=1} ^\infty \frac{(i \pi \hbar)^{2n} \left[\sqrt{(j-m)^{2n} (j+m+1)^{2n}} +\sqrt{(j+m)^{2n} (j-m+1)^{2n}}\right]}{2^{n+1} (2n)!} +\sum _{n=1} ^\infty \frac{(i \pi \hbar)^{2n+2} \left[\sqrt{(j-m)^{2n} (j+m+1)^{2n} (j-m-1)^{2n} (j+m+2)^{2n}} +\sqrt{(j+m)^{2n} (j-m+1)^{2n} (j+m-1)^{2n} (j-m+2)^{2n}}\right]}{2^{n+3} (2n+2)!} +... \right\} \mid j,m \rangle[/itex]
This coefficient goes on for as long as quantum number j allows.
The right side of the equation I am trying to prove has no operators, so the only non-zero coefficient I should have is the one for [itex]\mid j,-m \rangle[/itex]. This means that the coefficient for [itex]\mid j,m \rangle[/itex] should be 0 for all cases except when [itex]m=0[/itex].
The above series does converge, but to what it converges seems to depend on j and m. I have manipulated the series a couple different ways, but I have been unable to show that it equals 0 for all values of m except 0. I wonder if I am making this more difficult that it has to be. Any ideas?
Well you could always cheat and notice that all you're doing is turning a spherical harmonic upside-down :smile:
Your tip led me to realize that it would be simpler to think of it as a rotation applied to [itex]\mid j,m \rangle[/itex]. Then, I can use the Wigner D-matrix to simplify the expression:
[itex]R(\alpha , \beta , \gamma) \mid j,m \rangle =\sum _{m'=-j} ^j D _{m'm} ^{(j)} (\alpha , \beta , \gamma) \mid j,m' \rangle[/itex]
[itex]e^{-i \pi J_x}[/itex] can be written as [itex]e^{-i (-\frac{\pi}{2}) J_z} e^{-i \pi J_y} e^{-i \frac{\pi}{2} J_z}=R(-\frac{\pi}{2}, \pi , \frac{\pi}{2})[/itex].
Now I can use the Wigner D-matrix equation:
[itex]R(-\frac{\pi}{2}, \pi , \frac{\pi}{2}) \mid j,m \rangle =\sum _{m'=-j} ^j D _{m'm} ^{(j)} (-\frac{\pi}{2} , \pi , \frac{\pi}{2}) \mid j,m' \rangle[/itex]
[itex]=\sum _{m'=-j} ^j e^{-i(-m' \pi /2 +m \pi /2)} d _{m'm} ^{(j)} \mid j,m' \rangle[/itex]
[itex]=(-1)^{j-m} \sum _{m'=-j} ^j e^{-i(-m' \pi /2 +m \pi /2)} \delta _{m',-m} \mid j,m' \rangle[/itex]
[itex]=(-1)^{j-m} e^{-i(m \pi /2 + m \pi /2)} \mid j,-m \rangle[/itex]
So I'm close now, but it seems like they set [itex]m=j[/itex] to get to [itex]e^{-i \pi j} \mid j,-m \rangle[/itex], and I don't know why that step would be made.
