Angular Momentum; rod & disk inelastic collision
The discussion focuses on the calculation of angular velocity and kinetic energy following an inelastic collision between a plastic rod and a disk. The rod, weighing 2.50 kg and measuring 1.20 m in length, pivots at one end, while the disk, with a mass of 39.0 g, strikes the rod at a velocity of 33.0 m/s. The final angular velocity calculated is 1.226 rad/s, and the kinetic energy after the collision is derived using the formula KEf = 1/2 (Mdisk R^2 + [Mrod L^2/3]) w^2, where w is the angular velocity. The conservation of angular momentum is confirmed to be about the pivot point.
  • Understanding of angular momentum and its conservation principles
  • Familiarity with moment of inertia calculations for rigid bodies
  • Knowledge of rotational kinetic energy formulas
  • Basic proficiency in using LaTeX for equation formatting
  • Study the principles of angular momentum conservation in inelastic collisions
  • Learn about moment of inertia for various shapes, including rods and disks
  • Explore the derivation and application of rotational kinetic energy equations
  • Practice using LaTeX for formatting physics equations effectively
Students and educators in physics, particularly those focusing on mechanics, as well as anyone involved in solving problems related to angular motion and collisions.
tennisgirl92
The figure shows an overhead view of a 2.50-kg plastic rod of length 1.20 m on a table. One end of the rod is attached to the table, and the rod is free to pivot about this point without friction. A disk of mass 39.0 g slides toward the opposite end of the rod with an initial velocity of 33.0 m/s. The disk strikes the rod and sticks to it. After the collision, the rod rotates about the pivot point.
(a) What is the angular velocity of the two after the collision?
What is the angular momentum of an object moving with a linear velocity, about a given point? rad/s
(b) What is the kinetic energy before and after the collision?
KEi
= J
KEf
= J
L=Iw
(Iw+Iw)I=(iw+iw)f
w=v/r
KErot=1/2Iw^2
Irod=ML^2/3
Idisk=MR^2/2
I believe the set up would look something like this:
(Irodxwrod)i+(Idisk x wdisk)I=(Idisk+Irod)wf
The initial speed of the rod is zero, canceling that out.
MR^2/2 x V/R=(MR^2/2 + ML^2/3)wf
The problem I am having is we are not given the radius of the disk. Is it possible I am missing that the radius cancels out?
And again, with the KE, we need the radius in order to solve for angular momentum in the equation.
Thank you for any help!
Assume that the disk is a point mass. It appears you are conserving angular momentum. About what point is angular momentum conserved?
It would help us help you if you used LaTex for your equations.
Ok, so if this is a point mass I=MR^2, where r would be the distance from mass to the axis. So in this case, 1.2? Would this be applied on both the initial and final sides of the equation? I can see how it would be a point mass when attached to the pole, but why when it is solo?
And to answer what point angular momentum conserved, would this be at the pivot point?
I apologize but I do not know what LaTex is!
Thank you so much for your help.
Yes, but call the length of the rod L and put in numbers at the very end. Also, the mass of the disk is not equal to the mass of the rod, so use different symbols for the two.
Because, as you correctly pointed out, you are not given the radius of the disk, therefore you are to assume it's a point mass. If it were an extended mass, you would have to worry about exactly where on the rod its center of mass is stuck.
Yes. That's also the point about which you calculate all moments of inertia.
Look all the way to the left of the POST REPLY button. Click LaTeX to the right of the question mark. It is a powerful, easy-to-learn equation writer that you should invest some time in.
So here is my final set up.
MdiskR^2 x V/R=(MdiskR^2 + MrodL^2)w
which can simplify to
Mdisk xR x V=(Mdisk R^2 + Mrod L^2) w
I tried to make it clear-I will check out the LaTex when I have a little more time.
would this be an accurate set up? I obtained .4212 rad/sec, which seems small.
What is the moment of inertia of a rod about its end?
ah I forgot! ML^2/3
Mdisk R^2 x V/R=(MdiskR^2 +Mrod L^2/3) w
I now obtained 1.226 rad/sec, which seems more acceptable.
I trust you used R = L when you put in the numbers.
Yes! And this was the correct answer. THANK YOU for your help!
And one more question if you don't mind. For the KE after the collision, I understand this is now rotational kinetic energy which is 1/2Iw^2. We would use the w found in part 1, but for the moment of inertia would it be the combined values for the disk and rod? So:
KEf=1/2 (Mdisk R^2 + [Mrod L^2/3]) w^2
Yes.
Thank you! You are most patient and helpful. I really appreciate your time.
  • · Replies 71 ·
16K
  • · Replies 62 ·
13K
  • · Replies 18 ·
