Angular Velocities of rigid bodies at plane motionHelp me
The discussion revolves around the angular velocities of rigid bodies in plane motion, specifically focusing on a mechanism with defined positions and given angular velocity. Participants are tasked with determining the linear velocities of points A, B, and C, as well as the angular velocities of the mechanism's components.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between angular velocity and tangential velocity, with one suggesting the use of the formula V = ωR. There are attempts to calculate the linear velocity at point A and inquiries about the angles related to the shafts. Questions arise about the equality of velocities at different points and the need to find the instantaneous axis of rotation.
Participants are actively engaging with the problem, sharing calculations and seeking clarification on angles and relationships between velocities. Some guidance has been offered regarding the use of trigonometric relationships and the identification of the instantaneous axis of rotation, but no consensus has been reached on the final values or methods.
There are references to diagrams and angles that are critical for solving the problem, but some links to visual aids are broken. Participants express uncertainty about certain calculations and the relationships between the various points and their velocities.
adu1905
Angular Velocities of rigid bodies at plane motion..Help me please
Please Help for solve this problem.I really need it.It looks like is but not for me ...
For the given positions
OA=0,3m ;
AB=0,6m ;
BC=0,3m ;
O1B=0,5m ;
ωOA=2 s-1 of the part OA from the mechanism , shown in the drawing.
DETERMINE :
1-) The linear veocities of points A , B and C
2-) The angular velocites of every part of the given mechanism
Note= If a disk is given , the motion is realized without sliding.
Here is the link for figure.
http://www.yukleresim.com/viewer.php?file=43049722008396930993.jpg"
You mean:
ωOA = 2 rad/sec?
I think something got screwed in your text there.
Well, anyway, when you're given the angular velocity of a rotating object, and asked to find the tangential velocity of the vector at its edge, you just use the formula
V = ωR
V is what you're looking for, tangential velocity
ω is the angular velocity, in your case 2
R is the distance to the point/axis of rotation, in this case point O.
Can you get Va from that?
Va = 0,6m/s ...but i am not sure others..Please help me for others..Because Va is easy..But others are hard for me because i am high school :(
Thanks for Help ..Here is the my answers..But how can i find Vc...and angular velocities..
Your link isn't working anymore, I get "404 Not Found - The page or file you requested does not exist."
But your angle alpha is correct. I'm having a memory lapse with respect to beta-- I really need to see the exercise again.
If both angles are indeed 30 degrees than they are indeed equal (Va = Vb)...as far as Vc, well I'd like to see the diagram again.
aha i am sory about this...Here you are...yes alpha and Beta i think are equal...and then Vc is equal too ...Now i need one more help for angulae velocities ...thanks again :)
Actually you need the beta of the third drawing. Oops. My bad, I defined beta differently in the last image. That's the beta you need. You'll find out that's 60.
So it's really should be
Vacos(30) = Vbcos(60)
Which means they aren't equal.
As far as Vc, it's definitely not equal to the rest of them, but we'll get to that later. First you need to find P, the instanteneous axis of rotation,
I'd advise you to look at this image as an example problem to see how they locate P:
[PLAIN]http://img3.imageshack.us/img3/8868/solman222.jpg
Its location should be quite obvious, it's where the two tails of Va and Vb meet. You can use this formula:
Va = omega x radius
To find omega of that particular shaft.
Notice that the radius is the distance from Va to the instantaneous axis of rotation
Thanks for the hint :)...Here is the my answer can you please check it ..First picture is for the point P..I draw The all necessary points and shafts. Second picture is for the solving way...I am really glad to meet you :) ( sory for my language its not my main )
Happy to help :)
Are you telling me that the distance from Vc to P and the distance from Vb to P are equal?
Look at the trigonometry, see if it makes sense. To make think simpler, here is how you find the angular velocity of AB (I'm not familiar with the formula you used)
http://img691.imageshack.us/img691/2336/thisformula.jpg
You know Va, you know its angle to AB, you know Vb, you know its angle to AB, and you know the length. You can solve for omega
  • · Replies 53 ·
  • · Replies 61 ·
  • · Replies 18 ·
