ThomasMagnus
- 138
Problem:
Newton's 2nd Law for rotational motion states that the product of the moment of Inertia, I, and the angular acceleration alpha(t) is equal to the net Torque acting on a rotating body. Consider a wheel that is being turned by a motor that exerts a constant torque T. Friction provides an opposing torque proportional to the square root of the angular velocity w(t). The moment of inertia of the wheel is I.
A) Write out a differential equation that represents Newton's 2nd law for rotational motion in this case. Note that alpha(t)=w'(t)
B) If the initial angular velocity is w_o, determine the angular velocity as a function of time, w(t). Can you find an expression for w(t)
Attempt at Solution:
I was able to find the answer for A. I found that it was: I(dw/dt)=T-k(sqrt(w))
As for part B, I am really confused. I know I have to separate the equation and integrate it. I know that dw=w'(t)dt.Other than that I'm lost. First of all, should I be plugging in Wo now or at the end? I'm trying to isolate the w's but I keep getting:
I *w'(t)+k(sqrt(w))=T
I think I need to find a way to get the w's as a product or quotient of each other, so I can use dw=w'(t)dt.
