Angular Velocity from Potential and Mechanical Energy of rotating rod
To find the angular velocity of a falling rod when it meets the horizontal, the potential energy (U) can be equated to the mechanical energy at that point. The relevant equation is U = (1/2)MgL, where L represents the length to the center of mass. The moment of inertia (I) is also necessary for calculating kinetic energy (K), given by K = (1/2)Iw². The initial potential energy should use the altitude of the center of mass without the (1/2) factor. This approach correctly leads to solving for angular velocity (ω).
jstep
I am asked to find the angular velocity of a falling rod in the instant that the rod meets the horizontal. The system is set up in this image:
The only force acting on the rod is gravity
U = (1/2)MgL
K = (1/2)Iw2
Kf + Uf = Ki + Ui
Can I solve this by using the potential energy of the rod with this equation:
U = (1/2)MgL
and then equating that to the Mechanical Energy at the point that it meets the horizontal?
I know the moment of inertia of the rod so if I do (1/2)MgL = (1/2)Iw2 and solve for omega, is that correct?
Also, when finding the initial potential energy, should i use the full length of the rod or only the length to the center of mass?
Thank you!
yes, you are correct. to calculate the initial potential energy, just use the altitude of the center of mass and drop the (1/2), that should not be there.
good luck
Oh okay, so let me just make sure I understand:
so this is the correct way to find the initial potential energy?
U = mgLsin\theta
where L is the length to the center of mass
correct.
thanks so much!
  • · Replies 25 ·
  • · Replies 62 ·
13K
