Annihilation of shifted gaussian vs. nonshifted gaussian
Chip
Maybe a picture will help. http://chipreuben.com/annihilation-of-shifted-Gaussian.jpg
I get zero, both with the shifted and the non-shifted. Can anyone tell why the nonshifted should yield the ground state eigenfunction multiplied up by a constant? It seems the answer has to do with expanding in Fourier mode and then converting back to the distance domain...but I'm not sure.
The most simple thing is to just check the equation. You've given the ground-state wave function (a Gaussian) and then you can simply apply the annihilation operator and check the given relation. That shows that the "shifted ground state" is a coherent state.
Okay, I’m going to work in units where \hbar = m = \omega = 1. In this units, the momentum operator is simply
p = \frac{i}{\sqrt{2}} \ (a^{\dagger} - a) . \ \ \ \ \ \ \ \ \ \ \ \ \ (1)
Now, consider the translation operator, T(\epsilon) = \exp(- i \epsilon \ p), whose action on coordinate state is given by T(\epsilon) | x \rangle = | x + \epsilon \rangle , \ \ \ \ \ \ (2)
and define a state |\Psi_{\epsilon} \rangle by the action of T(\epsilon) on the ground state |\Psi_{0}\rangle:
<br /> |\Psi_{\epsilon} \rangle = T(\epsilon) \ | \Psi_{0}\rangle . \ \ \ \ \ \ \ \ \ \ \ \ \ \ (3)<br />
By multiplying (3) from the left with \langle x| and inserting the unit operator \int d \bar{x} |\bar{x}\rangle \langle \bar{x}| =1, we transfer (3) to a coordinate representation, i.e., equation between wave functions
<br /> \langle x | \Psi_{\epsilon}\rangle = \int d \bar{x} \ \langle x | T(\epsilon) | \bar{x} \rangle \langle \bar{x}| \Psi_{0}\rangle . \ \ \ \ (4)<br />
Using (2), we obtain
<br /> \Psi_{\epsilon}(x) = \int d \bar{x} \ \langle x | \bar{x} + \epsilon \rangle \ \Psi_{0}(\bar{x}) . \ \ \ \ (5)<br />
Now, change the integration variable \bar{x} = y - \epsilon, and use \langle x | y \rangle = \delta (x - y) to obtain
<br /> \Psi_{\epsilon}(x) = \int dy \ \langle x | y \rangle \ \Psi_{0}(y - \epsilon) = \Psi_{0}(x - \epsilon) . \ \ (6)<br />
So, \Psi_{\epsilon}(x) is the shifted ground state wavefunction \Psi_{0}(x - \epsilon).
Okay, now go back to (3) and let the operator a acts on it
<br /> a \ |\Psi_{\epsilon}\rangle = a \ e^{- i \epsilon \ p} | \Psi_{0} \rangle . \ \ \ \ \ \ (7)<br />
Since, a \ |\Psi_{0}\rangle = 0, we can replace the right-hand-side of (7) by the following commutator
<br /> a \ |\Psi_{\epsilon}\rangle = \left[a \ , \ e^{- i \epsilon \ p} \right] | \ \Psi_{0} \rangle . \ \ \ \ \ \ \ (8)<br />
If you now expand the exponential and use the relation
<br /> [a \ , -i \epsilon \ p ] = \frac{\epsilon}{\sqrt{2}}\ [a \ , a^{\dagger}] = \frac{\epsilon}{\sqrt{2}} ,<br />
you get
<br /> \left[ a \ , e^{- i \epsilon \ p} \right] = \frac{\epsilon}{\sqrt{2}} \ e^{- i \epsilon \ p} . \ \ \ \ \ \ \ \ \ \ \ \ \ \ (9)<br />
Substituting (9) in (8), leads to
<br /> a \ |\Psi_{\epsilon}\rangle = \frac{\epsilon}{\sqrt{2}} \ e^{- i \epsilon \ p} \ | \Psi_{0} \rangle = \frac{\epsilon}{\sqrt{2}} \ |\Psi_{\epsilon} \rangle . \ \ \ \ \ \ (10)<br />
In wave function language, this becomes
<br /> a \ \Psi_{\epsilon}(x) = \frac{\epsilon}{\sqrt{2}} \ \Psi_{\epsilon} (x) . \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ (11)<br />
And finally using (6), i.e., \Psi_{\epsilon}(x) = \Psi_{0}(x - \epsilon), we obtain
<br /> a \ \Psi_{0}( x - \epsilon ) = \frac{\epsilon}{\sqrt{2}} \ \Psi_{0}( x - \epsilon ) . \ \ \ \ \ \ \ \ \ \ (12)<br />
Notice that setting \epsilon = 0 gives you back
<br /> a \ \Psi_{0}(x) = 0 .<br />
Likes vanhees71
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
