Another First-Order ODE Question
  • Thread starter Thread starter bsodmike
    Ode
7 replies · 3K views
bsodmike
Going through a book on Numerical Methods, it states,
[tex]y' = 4e^{0.8x}-0.5y[/tex]
has the analytical solution,
[tex]y= \dfrac{4}{1.3}(e^{0.8x}-e^{-0.5x})+2e^{-0.5x}[/tex]
This is of the form,
[tex]y'+p(x)y=q(x)[/tex]
Should I use an Integrating Factor to solve the Linear ODE?, i.e. use an integrating factor [tex]\mu(x)=e^{\int{p(x)dx}}[/tex]
[tex]\mu(x)\left[y'+p(x)y\right]=\mu(x)q(x)[/tex]
[tex]\left(\mu(x)y\right)'=\mu(x)q(x)[/tex]
[tex]\mu(x)y=\int{\mu(x)q(x)dx+C}[/tex]
...and divide through by [tex]\mu(x)[/tex] ?
[tex]\mu(x)=e^{\int{p(x)dx}}=e^{0.5x}[/tex]
thus,
[tex]e^{0.5x}y=4\int{e^{0.8x}e^{0.5x}dx+C}[/tex]
and it is given: y(0) = 2
Any pointers? Dick, your help would be much appreciated once again!
Thanks and happy new year to all as well,
Cheers
Mike
Note: with p(t)dt, consider it as p(x)dx. I used some old latex definition I had already typed for the 'method'. i.e., rather than dy/dt, this is dy,dx. dy/dt = f(t,y) -> dy/dx = f(x,y).
*Definition updated in OP, w.r.t to (x).
Integral said:
When computing your integrating factor what did you use as your p(t)? Your integrating factor is not correct.
I used,
[tex]\mu(x) = e^{\int{p(x)dx}}=e^{\int{\dfrac{1}{2}dx}} = e^{0.5x}[/tex]
Well, isn't this,
[tex]y'+0.5y=4e^{0.8x}=y'+p(x)y=q(x)[/tex]
hence, [tex]p(x)=0.5[/tex] and [tex]q(x)=4e^{0.8x}[/tex] ?
Integral said:
[tex]e^{\int{\dfrac{1}{2}dx}}[/tex] Try doing this integral again. Where did the ln 2 come from?
Oooops! thanks for spotting that blatant error. [tex]IF=e^{\int{p(x)dx}}=e^{0.5x}[/tex].
This is what I am getting now,
Since,
[tex]\mu(x)=e^{\int{0.5\,dx}}=e^{0.5x}[/tex]
[tex]\begin{equation}\begin{split} <br /> e^{0.5x}y&=4\int{e^{1.3x}}\,dx+C\\<br /> &=4\left(\dfrac{e^{1.3x}}{1.3}\right)+C\\<br /> &=\dfrac{4}{1.3}e^{1.3x}+C<br /> \label{eq:}<br /> \end{split}\end{equation}[/tex]
Hence,
[tex]\begin{equation}\begin{split} <br /> y=\dfrac{4}{1.3}e^{0.8x}+Ce^{-0.5x}<br /> \label{eq:}<br /> \end{split}\end{equation}[/tex]
Where am I going wrong again?!?
*bump*
When I left the problem earlier as [tex]e^{0.5x}y=4\int{e^{0.8x}e^{0.5x}\,dx}+C[/tex], I thought I'd need to use integration by parts. But once I got it in the simpler form above (adding the powers) it just seems 'too simple' and the solution is missing a term.
*confused*...hmm..
