Another Q about double-slit experiment
The discussion revolves around the Young's double-slit experiment, specifically focusing on calculating the spacing between the slits using given parameters such as wavelength, distance to the screen, and the position of interference minima.
  • Mixed
  • Participants explore different formulas related to the double-slit experiment, with one suggesting a formula for calculating the distance from the central maximum to the minima. There is also a mention of frustration regarding the inability to use proper symbols in equations.
Some participants are attempting to clarify the correct formula to use for the problem, while others are providing alternative approaches. There is an ongoing exploration of the correct method without a clear consensus on the best approach yet.
One participant expresses frustration about formatting equations, indicating a potential barrier to clear communication of mathematical concepts. The discussion also hints at the need for clarity in the application of formulas related to the experiment.
aquabum619
Youngs double-slit experiment is performed with 589nm light and a distance of 2.00m between the slits and the screen. The tenth interference minimum is observed 7.26mm from the central maximum. Determine the spacing on the slits.
Iavg = (Imax) cos^2 [(pi d sin angle) / lambda]
(it is very frustrating not being able to insert relevant symbols )
hm you seem to be using the wrong formula, in this case we are not measuring the intensity but using: distance from central max= (wavelength * distance to screen*order number)/spacing of slits. Hoped that helped
589nm x 2.00m x 10 / .00726m = spacing of slits
1622589m between slits?
Sorry to change the topic, but look here for some info on LaTeX https://www.physicsforums.com/showthread.php?t=8997 if you want to make the equations look right
