Another spaceship and two points question....
  • Context: High School
  • Thread starter Thread starter TomTelford
    Points Spaceship
The discussion revolves around the synchronization and time readings of two clocks, A and B, in the context of special relativity. Participants explore the implications of a spaceship's motion relative to these clocks, examining how time appears to the pilot during acceleration and the effects of relativistic phenomena such as the Lorentz transform and the Doppler effect.
  • Tom describes a scenario where a pilot observes two clocks, A and B, with A reading noon and B reading 11am, and questions whether the pilot will perceive clock A as being one hour behind clock B after traveling to clock B.
  • Some participants clarify that the initial readings of the clocks do not imply that one clock is behind the other; they are synchronized in their rest frame.
  • There is a discussion about how the pilot perceives the time on the clocks during the flight, with some arguing that both clocks run slow relative to the pilot's clock, while others emphasize the effects of light travel time and the Doppler effect on the perceived readings.
  • Tom raises a scenario where the spaceship is moving towards clock A and questions how this affects the time reading on clock B when collocated with clock A.
  • Participants debate the nature of the Lorentz transform and its implications, with some asserting that it is a real effect while others argue that it depends on the chosen reference frame.
  • Tom seeks clarification on what the pilot would see regarding clock B's time when passing clock A, leading to further discussions about the interpretation of time readings and the effects of motion.
Participants express differing views on the interpretation of time readings and the effects of relativistic phenomena. There is no consensus on the implications of the Lorentz transform or the nature of the perceived time differences during the pilot's journey.
Participants note the importance of distinguishing between when events occur and when they are observed, highlighting the complexities of relativistic effects and the role of reference frames in interpreting time readings.
This discussion may be of interest to those studying special relativity, particularly in understanding the nuances of time synchronization, the effects of motion on time perception, and the implications of relativistic transformations.
TomTelford
Sorry if this has been done elsewhere but I haven't seen it.
Case: At the start a craft with a pilot is collocated at a position with a clock A with a second clock B one light hour away synchronized with A. All are motionless relative to each other. Clock A reads noon and B reads 11am. Good so far? The craft accelerates but not fast say .01c and eventually reaches clock B and stops. All I want to know is if the following is true: The pilot agrees that clock A is now one hour behind B as opposed to the other way around at the beginning?
Thanks.
Tom.
No. The two sentences quoted above contradict each other.
Sorry, to be more clear the pilot sees noon on Clock A and 11am on clock B. Better?
Ok; since clock B is one light-hour away, the clock reading seen from clock B at the location of clock A will be one hour behind the reading seen at the same instant on clock A. Yes, this is fine.
And the question you are asking, then, is whether the clock reading seen from clock A at the location of clock B will similarly be one hour behind the reading seen at the same instant on clock B. Isn't the answer obvious?
Note that this does not mean clock B is "one hour behind" clock A. Clocks A and B are synchronized; they have the same readings at the same times. So the reading "noon" on clock A happens at the same time (in the reference frame you are implicitly using, in which clocks A and B are at rest) as the reading "noon" on clock B. But someone co-located with clock A won't see the image of clock B reading "noon" until one o'clock by clock A.
In other words, you have to be careful to distinguish when events happen, in a given frame, with when those events are seen via light signals transmitted to distant locations.
Yes, but I'm laying bricks here and I want to be sure I'm not messing up anything.
The following then must be true that during the flight from Clock A to Clock B, Clock A would appear to the pilot to be running more slowly than Clock B to go from an apparent hour ahead to an hour behind. And that this effect would be true regardless of the effects of SR or GR.
I'll get to the meat of the question at this point.
In the case where the ship was not initially stationary but moving towards clock A in such a way as to be collocated with it when it read noon I believe Lorentz pops up at this point and says that clock B no longer says 11am as in the earlier case but something between 11am and noon. Am I heading in the right direction?
No. Once again, you are confusing when things happen with when they are seen.
During the pilot's flight, clocks A and B both run slow compared to the clock in the spaceship; and they both run slow by the same amount. The rates of clocks A and B are never different.
During the pilot's flight, the pilot sees clock B appearing to run faster than his own clock, and sees clock A appearing to run slower than his own clock. But these appearances are due to a combination of the changing light travel time from his ship to clocks A and B, and the relativistic Doppler effect caused by the ship moving towards clock B and away from clock A. When the pilot corrects for these effects, he finds, as stated above, that clocks A and B are both running slow relative to his own clock, and by the same amount.
No. Two observers who are co-located at a given instant will see the same light signals at that instant. So the ship will see the same image of clock B reading 11 am that an observer at rest relative to clock A sees.
What textbooks on SR have you read?
The problem is that you are asking other people if you are laying the bricks right, so if you communicate sloppily then we will give you incorrect feedback: correcting errors you didn’t intend and not noticing errors in your thoughts that were not expressed. Do make an effort, please.
Because of your wording I cannot tell if you correctly understand that he receives the 11am signal and calculates that A and B are not synchronized in his frame or if you erroneously believe that the actual image that he receives is not the 11am image.
So far you've messed up everything, so you might want to rethink this strategy.
What are you laying bricks for? What goal are you trying to reach?
That is exactly where I wanted to get to. There are two (at least) simultaneous effects going on while the pilot is flying; the Lorentz transform being a real effect and a doppler effect being virtual and self eliminating on the return trip.
You might want to reconsider thinking of the Lorentz transform as a "real" effect. The Lorentz transform depends on your choice of reference frame; you have it coming out a certain way because you have implicitly chosen a reference frame in which clocks A and B are at rest. In a different frame the Lorentz transform would give you different answers.
But what observers see--what light signals reach them at what points in their travel through spacetime--is invariant; it doesn't depend on any choice of reference frame. So those things have a better claim to being "real".
This ties into what I said before, that you appear to have a basic confusion between when things happen--which requires you to choose a reference frame--and what observers see.
Apologies, I'm listening to a lecture on relativity and I would accuse the lecturer of using ambiguous language.
All I wanted to know was that in case 1 pilot sees Clock A showing one hour ahead of Clock B at the start and the reverse at the end.
In case 2 changing only that the craft is moving throughout and starts at Clock A at noon, what does he actually see is the time on Clock B when he passes Clock A? It may appear closer or running slower or whatever, don't care at this point. All I want to know is whether the time is still 11am or some other time.
I've already answered that. Read post #9 again.
11 am
Thank you, I seem to have gotten my answer. Both cases show both clocks in the same configuration at the start. That's all I wanted to know.
@TomTelford - when studying relativity, it's important to make a clear distinction between what you see and how you interpret that.
Whatever their state of motion, everyone passing clock A when it reads 12 will see clock B reading 11. It can't be any other way, because they are receiving the same light from it.
However, observers can differ in how they interpret this. They all need to correct for the travel time of light to calculate what clock B is showing now. And what Einstein showed was that if everyone uses the same procedure to do that correction, they come up with different answers. Someone sitting next to clock A, at rest, says clock B is correctly synchronised and one light hour away. Anyone moving with respect to clock A says that both clocks are ticking slowly, they weren't synchronised correctly, and the distance between them is less than a light hour.
It's true that a lot of sources use "see" rather sloppily, meaning either or both of "directly observe" and "interpret their observations to mean"n so be wary (or find a better source). Keep in mind that the Lorentz transforms relate different observers' interpretations, not their actual observations. If you want to know what they see directly with their eyes, you need to add the light travel time back in.
The travel time for a light signal from an event to an observer is irrelevant to the theory of SR. If you have clocks on Earth one kilometre apart, then you hear one chime three seconds before the other and see one about ##3\mu s## before the other. And, if you could neither see nor hear the distant clock, but got your friend to run from one to the other to tell you, say, when it was noon by that clock, then you might not receive that information for 5-6 minutes later.
It makes no difference, in other words, whether you look at a distant clock, hear it chime, or get someone to convey a message by foot, bicycle or carrier pigeon. This time delay is irrelevant to the time that the event took place in your reference frame.
Many people imagine that the light-signal-travel-time from one event to another is critical to time dilation and the theory of SR generally. Which it is not. It's important, therefore, to disentangle any observational time lag from the theory as soon as possible.
In my view, it's important immediately to start thinking about "reference frames", rather than "what one observers sees".
To all who have responded, thank you and I do understand the distinction.
It is in fact the ambiguity of language that I'm dealing with here. When the lecturer uses phrases like "the person on the train sees...", they are implying 'after removing the effects of doppler shift' or 'only considering the effects of SR' but they don't say it. Meanwhile I'm caught here visualizing a clock ahead and one behind and it seems contrary to what is being taught. Specifically the lecturer suggested that since both observers see time running slower for the other, and, if the both observers must agree on the time on the "stationary" clock once they are collocated at the end of the trip then somehow the "moving" observer was being magically thrust into seeing the future beforehand merely by being moving. That can't be true. I can do the math, that's not the problem. I am beginning to understand SR conceptually but what I'm trying to do now is to take it from what would REALLY be observed, all in, all effects and to be able to say "ok, this part is doppler so take that out and this part is SR or GR".
Amongst other things I am a pilot. I deal with relativity every time I fly. I need to know how fast I'm going. Okay, relative to what? Well, the ground ideally but I can't do that directly. So I look at the airspeed indicator but it tells me only the indicated airspeed relative to the air. First I have to convert to calibrated airspeed to remove effects of the design of the system and that has to do with the speed of sound and hydrostatic pressure. Then I have to convert that to true airspeed based on atmospheric conditions. Then I have to convert that to ground speed based on what the air mass is doing relative to the ground. Training tells me how to do the math but I still have to build a sense of those relationships in my head in order to make it work while I am flying. An intuitive sense of this much change in power produces this much change in groundspeed.
That's what I'm trying to do with these questions. I do want to know what the relationship is between doppler and SR (or any other effects) during high speed flight as they are all going to happen AND to be able to calculate both. But I needed to know a couple of "absolutes" first and the questions above dealt specifically with the values perceived under specific circumstances not the rates of change of time during the action. SR deals with effects on rates of change but I needed to set the stage BEFORE asking the question of what happens once movement begins in order to understand it better.
There is only SR, which is "flat" spacetime. If you have a source of gravity, then you have curved spacetime and that is a whole different ballgame.
In particular, you do not have "Doppler" and "SR". You have SR, a theory of spacetime, which describes and explains (among other things):
Time dilation, length contraction and the relativity of simultaneity (between inertial reference frames)
The Lorentz transformation (of events between frames)
Relativistic velocity addition
The (relativistic) Doppler effect
Energy-momentum and its transformation
Particle collisions, and the energy-mass relationship.
etc.
Apologies again. Then I meant distinguishing between the elements of SR as you have listed them.
So moving on to the Lorentz part of this situation in case 2 is the following true:
The ship is moving at .5c as it passes clock A which reads noon and it "sees" clock B reading 11am. However the pilot thinks the distance to B is only .866 light hours not 1 lh away and that based on how quickly it observes time passing on clock B that it should read something like 12:07 if it were there right "now" in the ships frame as opposed to noon in clock A's frame?
I recommend looking up Minkowski diagrams, also called spacetime diagrams. They're essentially displacement-vs-time graphs, but since we interpret relativity as being about spacetime we take these seriously as a "slice" through spacetime. Or, at least, the best Euclidean representation of such a slice.
Once you've drawn a few from different frames you can build an intuition for how they transform. You can always add light rays to them and work out when they arrive at some observer if you want to know what they actually see.
I wrote a simple Javascript tool for drawing Minkowski diagrams, with animated frame changes. It works better on a laptop/desktop than a touchscreen, I'm afraid, but you can at least look at the "canned" scenarios if you want. www.ibises.org.uk/Minkowski.html
I make it that clock B reads 12.30 "now", according to the ship as it passes clock A. How did you get your 12.07?
I suggest you rephrase this:
In the ship frame:
Clocks A and B are moving towards the ship at ##0.5c##. They are 0.866 light hours apart in this frame. When Clock A reaches the ship, Clock A reads noon and clock B reads 11am (as "seen" from the ship).
(This is because clocks A and B are 1 light hour apart and synchronised in their rest frame.)
If we have another observer, X, at rest in the ship's frame, a distance of 0.866 light hours in front of the ship, then Clock A reaching the ship is simultaneous with clock B reaching X. X sees clock B read ... (calculation required).
Ibix,
Now I'm just trying to figure out which formula is used to solve which value being transformed. I was using t' of the distant event as being 1.14 times the 1 hour difference from the rest frame. At this point I was just trying to get a sense that the "now" of the distant clock would show a later time than the "now" of the rest frame.
I promise I will learn how to say these things using your phraseology.
TomTelford said:
Ibix,
Hint: first you have to work out where Clock B was (in the ship frame) when it read 11am. Or, more importantly, when!
That's if you insist on using your "delayed-signal-kinematics" approach!
Oh, last thing...
Time dilation and distance contraction are independent of direction, right? Distances behind you are equally contracted as those in front (or to the side) ?
TomTelford said:
Oh, last thing...
Length contraction is the same "front" and "back" in the direction of motion. But there is no length contraction in the directions orthogonal to the direction of relative velocity.
  • · Replies 36 ·
  • · Replies 50 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 58 ·
