Answer check and explanation(Linear transformation)
  • Thread starter Thread starter negation
    Transformation
negation
Find the standard matrix of the following linear transformation:
T(x1, x2, x3, x4) = (-2 x1 - 5 x2 - 4 x3 - x4, 2 x1 + 2 x2 - 5 x3 + x4)
[x1,x2,x3,x4] [-2,2;-5,2;-4,-5;-1,1]
=[-2 x1 - 5 x2 - 4 x3 - x4, 2 x1 + 2 x2 - 5 x3 + x4]
T(e1) = (-2,2)
T(e2) = (-5,2)
T(e3) = (-4,-5)
T(e4) = (-1,1)
A = [-2,-5,-4,-1; 2,2,-5,1]
The answer has been checked to be correct. But I'm not seeing why the standard matrix has to be transposed?
A matrix representing a transformation from ##R^4 \to R^2## would be a 2x4 matrix. The images of the basis vectors give the columns. Nothing is transposed that I see.
Likes 1 person
There are two problems with the above:
1. You have your x vector on the wrong side of A (it should be Ax rather than xA), and your matrix is wrong. You have four rows with two columns - it should be two rows with four columns.
negation said:
T(e1) = (-2,2)
T(e2) = (-5,2)
T(e3) = (-4,-5)
T(e4) = (-1,1)
The vectors on the right are all column vectors.
The transformation is T: R4 → R2, so the matrix for T will by 2 X 4 (i.e., two rows with four columns each).
Both of you guys are correct.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
