Answers: Inverse Function - Q&A
The discussion focuses on understanding the definition and conditions for a function to be considered an inverse function. A function is invertible if it is one-to-one, meaning each input corresponds to a unique output. The conversation highlights that simply having a function does not confirm its inverse; one must demonstrate that the conditions for invertibility are met. Additionally, the inverse function theorem is mentioned, indicating that an inverse does not exist if the derivative (Jacobian) is zero at any point. Overall, clarity in problem statements and precise definitions are essential for determining inverse functions.
baby_1
Hello
how can we know with the definition of inverse function
this function is inverse function or not?
trix}%20x%28t+1%29%20&%20x%28t%29\geqslant%200\\%200%20&%20x%28t%29\leq%200%20\end{matrix}\right.gif
another questions.
this function is inverse function because
but if we have this function
we can't do the same approach.why?(and it isn't a inverse function)
question 3:
in this function
why we can't get Integral and say x1=x2?
Mathematics news on Phys.org
I always thought an inverse function was one that undoes another function ... eg. if g(f(x))=x the g is the inverse function of f.
The definition above seem to be saying that there must be only one value for f for each value of x ... eg. f is invertable. But it cannot confirm that some other function g is that inverse - it can only refute it.
For your first example ... y is an inverse function of x if y(x(t))=t
To use the condition for invertability - you can attempt to show that x or y is invertable from the information supplied.
x is invertable if x(t=t1) = x(t=t2) means that t1 = t2
But even if they are invertable, this will not show that y is the inverse of x.
It can help to look closely at the exact question to check what you are being asked to do.
Thanks smimon for explanation
it is possible and could you solve the problems with your way? how did you know that y(x(t))=t?
sorry I am not celever as you
Definition of the inverse.
If y(t) is the inverse function of x(t) then y(x(t))=t
Probably - but you need to be exact about what the problems want.
As they are written I can't tell.
The answer is no if x(t) is defined to be 0 at more than one point since it maps all these points to one point.
As mentioned earlier, a function has inverse it it is 1-1: in other words, every value produced for the input generates an output that is different to every other input.
You can restrict the inverse to a subset of the domain, but this means that you are looking at a different function since the domain is different (even if the nature of the mapping is the same, since functions require information about the exact nature of the domain and codomain).
Also one thing is that if you know the derivatives of x(t) then you can definitely answer the question with more precision since the inverse function theorem says that an inverse doesn't exist around the neighbourhood of a function mapping when the Jacobian is zero (for 1-D function, this is just the first derivative).
Though that could be a typo...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
