Antenna spacing and interference
The discussion centers on the functionality of dual antennas in a Cisco router's WiFi card, which are spaced about an inch apart and can pivot. The antennas do not destructively interfere because they are not driven simultaneously; instead, they utilize spatial diversity for receiving signals. The receiver circuit selects the strongest signal, allowing one antenna to pick up a signal while the other may be in a null zone due to multipath effects. More complex systems can adaptively determine which antenna provides better signal strength, but this may not always be beneficial due to dynamic multipath conditions. Overall, the design enhances signal reception without interference issues.
oneamp
I have a wifi card for a cisco router that has two antennas spaced about an inch apart. The antennas can pivot so that the distance between the same point on either antenna can change. Since the antennas don't remain a wavelength multiple apart at all points on them, why is it that they don't destructively interfere with each other?
Thank you
Thank you
They aren't driven at the same time. Dual antennas in WiFi are generally used for "spatial diversity" in RX. The RX circuit uses whichever RX signal is the strongest. Because of multipath, one antenna can be in a deep null, but the other antenna spaced a bit away will generally not be in the same null...
So the system just picks one to transmit?
There are different ways to use the two antennas, but that's one of the simpler ones -- TX on one antenna, and RX on both (either at the same time if your PHY chip can handle it, or switch sequentially between them if the TX device is retrying because you can't hear it on your primary antenna).
A more complicated system can use the two antennas to query a node it wants to reach, to see which TX antenna gives a better receive signal strength indicator (RSSI) reading at the RX device. But in systems/channels where the multi-path can change dynamically, that kind of adaptive learning may not be worth it.
Here's a wikipedia article that discusses antenna diversity and multipath...
http://en.wikipedia.org/wiki/Antenna_diversity
:smile:
Thank you
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
