Are Other Planets Headed for Organic Evolution?
  • Thread starter johncena
In summary, the conversation discusses the possibility of other planets undergoing organic evolution like Earth, the idea of creating artificial organic evolution on other planets, and the chances of finding life on other planets through methods like the Kepler Mission. The conversation also touches on the Drake Equation, the number of particles in the universe, and the likelihood of finding a planet similar to Earth. It ends with a discussion on the potential for finding life in the galaxy based on the age and magnetosphere of a planet.
johncena
131
any more Earth's?
like earth, will the other planets makes organic evolution in the near future?
Unlikely. Conditions on the other planets in our solar system are not favorable toward life.
Look up the "Goldilocks Zone". It refers to the stellar systemic zone in which planets can harbour water-based life. Earth is the only one in it. Mars is right on the edge.
can we create artificial organic evolution in other planets?
Evolution of living organisms is a process that occurs at a snail's pace in human terms. We would not see much in the way of results in the lifetimes of the people involved.
Just to pose an idea, would it ever be possible in theory to detonate several nukes on Mars to blow it into the goldilocks zone?
Nukes wouldn't be the answer, you'd use a method that slow and gradual.
But the problem is that, Mars at that distance would perturb the Earth's orbit and the two orbit might not be stable.
What kind of gradual force would you suggest?
We're fantasizing here, right? I mean, we're talking about moving worlds.
This needs to be stated because PF has an "overly-speculative posts" policy.
Anyway, you'd do something like this:
Put a low impulse, long-running engine like an ion engine or VASIMR engine on an asteroid.
Use the engine to move the asteroid into Mars orbit.
Move the asteroid using the engine, Mars will follow.
Read up on "Gravity Tug".
The Kepler Mission was recently launched. The goal of this program is to search for earth-like planets in the so called goldilocks zone. However, this would only demonstrate that a particular planet is at the correct distance from it's sun to allow the possibility for organic life to occur on that planet. It would be miles from proof for actual life on that planet.
Fantasy of course.
That's a brilliant idea to use an orbitting asteroid to slowly tug at the planet its orbitting.
If you calculate how many particles there are in the U then suppose they can create an Earth the probability comes to zero we are an enigma. the drake equation is just so bogus
First off I'm not entirely sure what you mean because your grammar is lacking some commas. Secondly, by creating an Earth do you mean a particle for particle verbatim copy of the Earth? Then I would agree, even though I've not done the math, so its merely a gut instinct. But, I would say there is a very high probability that there are many planets very similar to the Earth in size, elemental composition, proximity to star, moon orbits and atmospheric conditions. There are other factors indeed, but in my opinion if you have these basic components mimicing (sp?) the Earth, then the planet would likely host or be suitable for hosting life.
Where do you get the # of particles in the Universe from? This also assumes a static universe, which we observe as false and it assumes nothing beyond the observational horizon which is a moot point, but still must be lightly considered.
Why air does not go out of the Earth plenit while air pressure is low out side
Gravity! There is no force pulling it away from the earth.
There was a SciAm article on this a few years back. If we posit an unending universe, then it is easily calculable how far we'd have to go to find an identical Earth. It was a surprisingly short distance, something like 10^150 metres.
You missed an exponent. That was Max Tegmark's paper for SciAm and the minimum he quoted was 10^10^26 metres i.e. a double exponential.
OK, that's a little bit farther...:tongue:
Life in the galaxy?
If one surveys stars, and their planetary systems, of 4.5 - 5 Byrs old; and then detects terrestrial exoplanet of say 1.5 Earth masses, then one probably still has a magnetosphere - if we are typical (Copernican Principle). And if in habitat zone, then also look for oxygen signature in atmosphere, from very far distance (lyrs). So if photosynthesis for such a long time of 5 Byrs (stromatalites 3.5 Byrs ago for us), then would there be some probability of a species developing culture? Then consider large numbers fall out for our galaxy of 100-200 B stars.
Well it sounds like a nice and fuzzy idea but I cringe when people do probabilistic calculations with data sets that are incomplete and admittedly inaccurate. Don't they have better things to do? :)
I guess we have been before, philosophizing why the Drake equation is not science, because you can't test it.
Apart from that, if we don't understand why Venus is the way it is, for instance the lack of spinning and the geology (or Venulogy perhaps?) of 'catastrophic?' resurfacing and extreme high surface temperatures and high thermal gradients of the lithosphere in the past, seem to have little to do with the goldilox zone. If that had happened on Earth then we would not have been here. The Drake equation does not account for that.
It's not probabilistic. It's permutative. And it does set down some preconditions.
I think the only precondition is that the universe is homogenous and infinite in extent.
That being the case, there are only a finite number of ways that a volume of space can arrange itself.
If you have four types of egg (white, brown, double-yolk and speckled) and an infinite plane of eggcups, how many permutatons of the four eggs can you lay down before you run out of unique patterns and must start repeating?
Now, what if you have 10^60 eggs?
The answer is a pure mathematical derivation.
The calculation is worthless imho, aside from making magazine covers.
What do you mean by homogenous? As far as I know the Universe does not have a density that can be smoothed over to create an average density that would closely plot the actual density for all the regions of space. Not on a small scale (galaxy size) nor on the grandest scale (entire universe). The fringial regions are dominated by massive quasars, whilst the inter-stellar regions are barren undense regions. You would never expect to find a planet in either of these regions, let alone an Earth like planet.
I would pull any grant money researching such absurdities. This is not good physics or cosmology imho. Its an armchair calculation done to enshrine oneself into the legacy of being the man who told the world how long it would take before they saw themselves again.
Also, did he consider the living beings on Earth? How long before I bump into an Earth where you and I are sitting where we are at this moment, etc.?
Garbage!
Of course. : clap clap clap : You should be very pleased with yourself.
I'm not sure why this is confusing you. Homogenous is pretty straightforward.
In general, if we were able to examine a region of the universe an arbitrary distance from ourselves, it would on a large scale, be similar. Which means:
These "fringial regions", do you mean "at the edge of our observable universe"? Are you suggesting that, if we look at the same distance in every direction we will see a different makeup of he universe? Because if you do, the implication of that is that we are at the "centre" of something.
As for finding a planet in these regions, you are thinkng too small. Massive quasars and undense regions are small-scale deviations - blips - on the scale we're talking about.
Obviousman strikes again. But you're making it sound like you're seeing with a clarity that no one else is.
Yes. With the postulate that the universe is infinite and homogenous, the conclusion is that there is an exact duplicate of you, and me, sitting in our very houses.
It is no more a ridiculous conclusion as, for example, the MWI is as a valid interpretation of quantum mechanics.
Wow Dave, I'm not sure why you are berating me. Mr. Obviousman? Clap clap clap? Very childish behaviour Dave, tisk tisk. I didn't pick a fight with you, why are you picking one with me?
Anyhow, back to adult business... by homogenous, you mean the distribution of galaxies? Or the CMB? Or something else?
Please no more insults.
1. What is organic evolution?
Organic evolution is the process by which living organisms change and adapt to their environment over time. It involves genetic variation, natural selection, and genetic drift.
2. Are other planets capable of organic evolution?
It is currently unknown if other planets are capable of organic evolution. So far, Earth is the only planet where we have evidence of life and organic evolution.
3. What conditions are necessary for organic evolution to occur?
Organic evolution requires a few key conditions, including a source of energy, genetic material, and a stable environment. Water also appears to be a crucial component for the development and sustenance of life.
4. Can organic evolution occur without the presence of water?
Based on our current understanding, it is unlikely that organic evolution can occur without the presence of water. Water is essential for biochemical reactions and serves as a solvent for many important molecules in living organisms.
5. Is there evidence of organic evolution on other planets?
Currently, there is no conclusive evidence of organic evolution on other planets. However, there have been some promising discoveries, such as the presence of organic molecules on Mars, that suggest the possibility of past or present life on other planets.
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
  • Biology and Medical
